RIPDOTCOM
Joined: 17 Mar 2006 Posts: 57 Location: Tallahassee, Florida
Posted: Thu Jun 15, 2006 3:14 am Post subject: How do you adjust the idle? |
| Is there a way to adjust the idle on the 924s? |
Posted: Thu Jun 15, 2006 7:21 am Post subject: |
| NO, the idle speed is governed by the computer. If you engine has an idle speed problem, then the engine has a problem that needs correction. Could be as simple as a leaking or disconnected vacuum line or electrical sensor. |
Posted: Thu Jun 15, 2006 8:49 am Post subject: |
Or a bad grounds on the back of the motor under the heater control valve, a bad hose on the idle control solenoid, or a bad idle control solenoid, a bad TPS, among many others. _________________ White 87 924S "Ghost"
RIPDOTCOM
Posted: Fri Jun 16, 2006 2:25 am Post subject: |
| Nevermind, I figured it out. Jumped the controller and adjusted it to 1100RPM. When i had the head shaved it was shaved to pretty much maximum tolerance thereby raising the compression. The idle at 900rpm was a littly shaky but it smooths way out at 1100.00 Initially I thought it was a broken motor mount. Hold steady and 100% smoother idle. |
