seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Mon Jul 10, 2006 11:05 pm Post subject: safe removal of 911 style three spoke steering wheel |
have asked this in the how-to section to, but perhaps this area is more often looked at.
I need to remove the steering wheel so I can have a go at fixing the odo, and haven't tried to remove one like this before. I have done the lozenge type wheels before. How do I safely remove all the horn etc without breaking anything!
type of wheel shown here:
http://www.pistonheads.com/sales/82134.htm _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Tue Jul 11, 2006 12:31 am Post subject: |
The horn pad just pops off and then you will see the nut to remove the wheel. The only care you need to take is that the horn wire is connected to the pad so you want to take some care not to break the wire.
Making a mark on the outside of wheel column will ensure that it goes back on properly aligned.
(on my cars, the nut came off pretty easily. If yours doesn't, you will need to brace the wheel to get it loose and others will have to advise you on how to do that) _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
seanski44
Posted: Tue Jul 11, 2006 12:37 am Post subject: |
| Stu2j wrote: | >>How do I safely remove all the horn etc without breaking anything!
(on my cars, the nut came off pretty easily. If yours doesn't, you will need to brace the wheel to get it loose and others will have to advise you on how to do that) |
Cheers  _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Posted: Tue Jul 11, 2006 12:47 am Post subject: |
the nut will be 24 mm as well to save you time _________________ 3 928s, |
seanski44
Posted: Tue Jul 11, 2006 2:49 am Post subject: |
thanks all! - to quote a famous film "...all too easy..." _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Posted: Tue Jul 11, 2006 8:09 am Post subject: |
After removing the horn push-Loosen off the nut but leave it on the shaft.
Pull on the wheel until it comes loose. A good pull top and bottom and then the sides and just keep it up till its loose.
Remove nut and wheel.
(prevents you getting a face full of wheel) _________________ Porsche 924 1984 (UK import) NA
tux
Joined: 02 Jul 2006 Posts: 133 Location: Nottingham UK
Posted: Tue Jul 11, 2006 8:23 am Post subject: |
| Ozzie wrote: | After removing the horn push-Loosen off the nut but leave it on the shaft.
(prevents you getting a face full of wheel) |
I'll wager thats the voice (typing?) of experience! I know I've done it more than once.  _________________ Pete
Merlin Guards Red 1985 N/A |
Posted: Tue Jul 11, 2006 2:21 pm Post subject: |
I'm not going to say how stupid and inexperienced I was. _________________ Porsche 924 1984 (UK import) NA
Posted: Tue Jul 11, 2006 5:00 pm Post subject: |
Getting the wheel off is the easy bit. Wait 'til you get to unplugging all the switch gear... and if you though that was bad, wait until you try to put it back together! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
seanski44
Posted: Tue Jul 11, 2006 7:34 pm Post subject: |
he he he, cheers guys, got the wheel off OK, thought I'd fixed the speedo so its all been back together again and out for a test drive and back into pieces since I realised how short term the 'fix' I did was....
still trying to work out the best way to space out that cog (see other thread) _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Vince Ponz
Posted: Tue Jul 11, 2006 10:38 pm Post subject: |
Why did you ever remove the steering wheel to get the speedo out. It is not necessary. I have removed about 6 speedos and never had a problem. I also switched the speedo spot with the tack and vs versa.
CAUTION......If you attempt to remove 24 mm nut with a breaker bar be careful not to hit the windshield when it breaks loose. NO I never hit the windshield. Almost. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
seanski44
Posted: Tue Jul 11, 2006 10:53 pm Post subject: |
| Vince Ponz wrote: | Why did you ever remove the steering wheel to get the speedo out. It is not necessary. I have removed about 6 speedos and never had a problem. I also switched the speedo spot with the tack and vs versa.
CAUTION......If you attempt to remove 24 mm nut with a breaker bar be careful not to hit the windshield when it breaks loose. NO I never hit the windshield. Almost. |
just made it easier.
and as for swapping the tach and the speedo, I'd like to, but the cable which comes off the back of the speedo and plugs into the tach won't reach - is there a way around that?
EDIT: p.s. it'd be hard to hit the windscreen with a breaker bar while loosening the wheel in a Right hand drive  _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
