hot start quick ?
plyhammer
PostPosted: Tue Jun 06, 2006 1:36 am    Post subject: hot start quick ? Reply with quote
On the typical hot start topic, does the engine crank and won't catch or do you get nothing when you turn the key?
Chrenan
PostPosted: Tue Jun 06, 2006 1:38 am    Post subject: Reply with quote
The engine cranks and cranks and cranks with no start.
924er
PostPosted: Tue Jun 06, 2006 2:11 pm    Post subject: Reply with quote
yep true
80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
Min
PostPosted: Tue Jun 06, 2006 2:17 pm    Post subject: Reply with quote
just hope it fires up before you drain your battery. btdt.
Min
PostPosted: Tue Jun 06, 2006 4:38 pm    Post subject: Reply with quote
...then you get nothing when you turn the key!
plyhammer
PostPosted: Wed Jun 07, 2006 12:10 pm    Post subject: ok then what could it be? Reply with quote
I thought that I had the hot start problem but my car will do absolutley nothing after getting hot. If I shut off the car when it is hot it will have to sit for an hour before it starts? What else could it be?
StienbargerR
PostPosted: Wed Jun 07, 2006 12:19 pm    Post subject: Reply with quote
Maybe it is just a loose wire. That would make sense to me, the temperature might cause something to break connection or vice versa.
Ryan
1978 924 NA
PostPosted: Wed Jun 07, 2006 12:21 pm    Post subject: Reply with quote
Or a bad starter solenoid. Is your heat shield still installed on the starter?
StienbargerR
PostPosted: Wed Jun 07, 2006 12:22 pm    Post subject: Reply with quote
Ryan
1978 924 NA
