doomer77
Joined: 10 Jan 2006 Posts: 266 Location: Huskvarna, Sweden
Posted: Sat Jun 03, 2006 9:03 pm Post subject: permanently damaged? |
my car has had its ups and downs, and now it might be in for the final judgement..
couple of months ago my front wheel stabilizer bar started making clacking sounds that got worse and worse over time, solution: change it. however the car has been crashed (long time ago, repaired now) and the bodywork is a little bit bent out of shape, could it be that the bent body is causing the stabilizer to break prematurly. in this case i would have to put a new one in every few months.. and the car would not be of much good _________________ Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES |
Stampedetrail
Posted: Sat Jun 03, 2006 9:08 pm Post subject: |
Maybe use a better heavy-duty stablizer bar setup instead of junking the frame. Just a thought. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Posted: Sat Jun 03, 2006 9:12 pm Post subject: |
Sway bars never break, they can be bent, but I've never seen one break.
Are you talking about the end links? _________________ White 87 924S "Ghost"
PORSCHEV
Posted: Sat Jun 03, 2006 9:18 pm Post subject: |
Try changing it once....I am sure that will be the end of it for years.  _________________ 1976 924
1978-#53 "D" track racer. |
doomer77
Posted: Sun Jun 04, 2006 2:22 am Post subject: |
ill try it and i sincerly hope so.. _________________ Why drink and drive when you can smoke and fly?
1989 Volvo 480ES |
