Headlights
PostPosted: Sun Apr 30, 2006 10:42 pm    Post subject: Headlights Reply with quote
Just a point of interest about the headlights.
The ROW car 7" round headlights are not a cheap pick up anywhere replacement.
Apparently they made some changes and for some reason removed the retaining ring and incorporated it into the headlight itself.
Now I have a set of headlights to sell.
tj924
PostPosted: Fri May 19, 2006 1:19 pm    Post subject: Reply with quote
Damn! One of mine is broken (smallish hole in the glass, but the light is still working) & I was hoping to get "a cheap pick up anywhere replacement".
Looking at the PET PDF file, section 905 (headlamps), are you saying part number 477 941 046 (retaining frame) is part of what PET calls the headlamp (part number 477 941 773 I think, which has a remark of "/RL" next to it, which I believe means "right-hand drive")? Got any pics of it?
I'll have to check mine out one of these days & see if it the same.
TJ
PostPosted: Fri May 19, 2006 3:03 pm    Post subject: Reply with quote
There is a different headlight for the us/cdn cars where the light has a ring holding it to a frame.
The ROW cars have the ring as part of the light
tj924
PostPosted: Fri May 19, 2006 4:19 pm    Post subject: Reply with quote
Strange that it isn't listed in the PET then
TJ
PostPosted: Fri May 19, 2006 5:05 pm    Post subject: Reply with quote
TJ - If I was you, I'd try and get a similar headlamp from a scrap Golf, say, for a few dollars, offer it up and just see if it fits or not.
If it does you're quids in (dollars in your case), if not you'll be able to see what's different. It may be that you can adapt the frame in some way. In any case you won't have lost much and you'll have learned from the experience...
PostPosted: Fri May 19, 2006 5:48 pm    Post subject: Reply with quote
Our light is 477 941 775 C where the US is for post '81- 999 631 127 90.
Its shown on illustration 905-00 and 905-05 in PET
I just bought 7" lights with the crystal lens and had to resell them as they were not gonna fit as there was no fixing points.
PostPosted: Sat May 20, 2006 10:16 am    Post subject: Reply with quote
And here I mistakely thought a 7" sealed beam fit all 924s.....
Learn something every day...
PostPosted: Sat May 20, 2006 12:15 pm    Post subject: Reply with quote
Probably be a smart move to get US type ring and frame. Then a standard pair would fit instead of having to go genuine.
N-Dub
PostPosted: Sun May 21, 2006 6:45 am    Post subject: Reply with quote
When I got new headlights, they were in stock at Checker Auto Parts. The guy behind the counter said that they were the same headlights as Jeeps. Don't know if that helps?
'79 924 now Totaled! Carrera GT bodywork for sale!
'87 951
PostPosted: Sun May 21, 2006 8:08 am    Post subject: Reply with quote
US cars are different.
tj924
PostPosted: Tue May 23, 2006 3:28 pm    Post subject: Reply with quote
Hmmm. I can only find illustration 905-00 in PET, not 905-05. I can't find either of the part numbers in either the PET PDF that is referenced on the forum or the CD-based PET program.
The only part numbers I can find for Headlamps 477 941 771 B (with nothing under "remark") & 477 941 773 (with /RL under remark).
TJ
PostPosted: Tue May 23, 2006 4:40 pm    Post subject: Reply with quote
On the pdf it goes to 905-10 and skips any between 905-00.
On the PET program it is the next page on mine.
The 477941773 number appear to be good on this site http://www.design911.co.uk/index.htm?Region=UK
And the bird
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=477941773&I1.x=12&I1.y=5
Not cheap though and then freight on top.
PostPosted: Tue May 23, 2006 4:47 pm    Post subject: Reply with quote
There must be at least one more part number for 924 headlamps, because at some point they changed from sealed beams to halogens.
Maybe it's time for a conversion, TJ.
PostPosted: Tue May 23, 2006 4:50 pm    Post subject: Reply with quote
I thinks I'll be converting to the US style when the time comes.
You'll need the frame and retaining ring.
How about getting someone to send these to you who has done the fixed light conversion?
You can get the lights here.
tj924
PostPosted: Tue May 23, 2006 4:58 pm    Post subject: Reply with quote
Mine are already halogen. That could be the diffrerence between headlamp part number 477 941 771 B & 477 941 773 in PET illustration 905-00. It also lists a halogen bulb (H4) as 999 631 202 90 (& 91)
TJ
