Display your expertise / collect advice needed!
doomer77
PostPosted: Tue May 09, 2006 9:08 am    Post subject: Display your expertise / collect advice needed! Reply with quote
Ok, there has been some talk about putting together a thread which would ask as an introduction to new 924 owners. on the list of ideas are car history, advice, interesting stories, mechanical goodies, and so on and so forth.
first of all though we are going to put toghether a checklist (hopefully arranged in order of priority). so please, share some of your knowledge about things that needs to be done immidietly after getting a new car. anyone can post as no advice will be dissregarded.
ill start us off with the easy ones.
provided that the seller doesnt have any information regarding changes or if the car has been standing still for long
1. Oil filter
2. Fuel filter
3. Air filter
another thing that is very important concidering it's such an old car is greasing up the ball bearings in all wheels. these bearings will run out of grease and eventually brake, several hundred dollars..
you keep it going!
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
Porscheaddiction
PostPosted: Tue May 09, 2006 9:32 am    Post subject: Reply with quote
new sparkplugs
vac hoses
coolant hoses timming belt and tensioner
alternator belt
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
leadfoot
PostPosted: Tue May 09, 2006 9:51 am    Post subject: Reply with quote
2nd ground strap from motor to chassis + rewire alternator/starter motor loom to battery...
clean all ground points
ensure all fuses are in place and clean contacts for fuses at fusebox - check to see if any relays have corrosion on their pins...
flush cooling system
change transmission fluid
inspect ball joints, change tie rods/rod ends , check rear ride height is level with front, check shock absorbers and have a wheel alignment done.
leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Tue May 09, 2006 10:12 am    Post subject: Reply with quote
Flush/change brake fluid
Replace rubber brake hoses if they are more than 10 years old
WhoDak
PostPosted: Tue May 09, 2006 10:28 am    Post subject: Reply with quote
Clean steering column electrics.
Check seat mounting bolts.
Parking/main brake adjustment(4-bolt drums in rear).
Tire pressure.
Check CV boots and bolts.
Check steering arm boots.
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
Slam
PostPosted: Tue May 09, 2006 11:59 am    Post subject: Reply with quote
Water leaks at battery box.
Cam oiler elbow.
Timing belt tensioner.
Water pump.
I've found twice now that the 924 t-belt tensoner will warn of impending failure because the belt will start to 'walk' as the tensioner bearings start to fail.
PostPosted: Tue May 09, 2006 1:13 pm    Post subject: Reply with quote
Wiper blades.
Crank breather hose.
Engine mounts.
PostPosted: Tue May 09, 2006 1:30 pm    Post subject: Reply with quote
clean grounds for fuse box, and replace fusebox with a new unit.
3 928s,
PostPosted: Tue May 09, 2006 3:51 pm    Post subject: Reply with quote
Guys, this is fantastic stuff - I've just picked up my first 924, so am taking your suggestions and turning them into a complete list that I'll get right onto this weekend - if not earlier!
Keep it going...!
Tigger937
PostPosted: Tue May 09, 2006 4:31 pm    Post subject: Reply with quote
Camshaft & followers for signs of wear
Adjust valve lash
Proper operation of cooling fan(s)
Using high pressure air hose, back blow the radiator to clean
Oil in coolant, coolant in oil
Antifreeze set temp.
compression/leak down check
Plugs for signs of engine problems
Add can of water pump lube & antirust followng flush, bleed the system
fuel injector spray pattern
get yourself a spare fuel pump relay
and belts
and fire extinguisher rated for electrical & gas fires
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Tue May 09, 2006 4:59 pm    Post subject: Reply with quote
Oil change has been mentioned, but if you're not sure how regularly the PO has changed the oil in the past, I would recommend an engine flush (or two!) before changing the oil.
Apart from that, it's just a general thorough maintenance routine, as with any car with an unknown history.
doomer77
PostPosted: Thu May 11, 2006 12:44 am    Post subject: Reply with quote
bump!
lets keep this going people
1989 Volvo 480ES
JB 924
PostPosted: Fri May 12, 2006 1:21 pm    Post subject: Reply with quote
Check intake for oil
PostPosted: Fri May 12, 2006 1:30 pm    Post subject: Reply with quote
I assume you mean the intake manifold? I noticed a small amount of oil on my manifold last night - but running the engine didn't seem to produce any more. Not sure if PO did a sloppy oil top-up, or if it's something more sinister...?
PostPosted: Fri May 12, 2006 1:51 pm    Post subject: Reply with quote
No worries mate, oil in the intake is more of a concern for the turbo models since it usually means blown turbo seals.
