No spark-any ideas?---Problem Solved
Al
PostPosted: Thu May 18, 2006 12:09 pm    Post subject: No spark-any ideas?---Problem Solved Reply with quote
A while back I had asked for help on why there wasn't any spark, even though I had some voltage to the coil. I had some really great advice and just wanted to thank everyone for the help. The solution ended up being the "reluctar", which is found inside the distributor, and resembles a magnetic pick-up. It evidentally sends a signal to the ignition module which in the end, makes spark. I also changed the ignition module, distributor cap and rotor, and of course spark plugs. Done a little tweaking with the timing light and the car is running probably the best it has ever run. A far cry from when I bought it from the scrap yard!
Just wanted to let others know in case they have the same problem.
