Hello everone i have just joined this forum
martin924
PostPosted: Sun May 14, 2006 2:45 am    Post subject: Hello everone i have just joined this forum Reply with quote
Hello... i have a just bought a beautiful 1985 924 and i love it allready but the oil pressure gauge does not work. the standard oil pressure light on the main panel works fine, but the one reading the actual pressure goes all the way to 10 when you switch on the power and it stays there it does not come down to read the actual pressure when the engine is running, will it be the sender opr the gauge is theis a comman falt? thank you for any help at all, regards Martin
PostPosted: Sun May 14, 2006 3:36 am    Post subject: Reply with quote
Hi, welcome aboard.
First check the sender itself to see if its' contacts are grounding - there's some alumin[i]um foil insulation on the firewall less than an inch from the sender that can bend down and touch the contacts. The sender is behind the cylinder head, between it and the firewall.
Porscheaddiction
PostPosted: Sun May 14, 2006 3:55 am    Post subject: Reply with quote
Welcome to 924 ownership a great group of people here to associate with and learn from.
Smoothie is right check that first.
Chris.
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
martin924
PostPosted: Sun May 14, 2006 9:33 pm    Post subject: Hello again Reply with quote
Thank you for your replies, the ali shield is not a problem on my car ill clean the connections and if that does not work, ill get one off ebay! Regards Martin,
ps is it more likely to be the sender or the gauge??
PostPosted: Sun May 14, 2006 10:13 pm    Post subject: Reply with quote
Welcome and more than likely the sender.
doomer77
PostPosted: Mon May 15, 2006 2:32 pm    Post subject: Reply with quote
had the same problem, porsche garage told me it was the sender and the only way to fix it is to replace with a new one
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
PostPosted: Mon May 15, 2006 5:20 pm    Post subject: Reply with quote
Welcome, Martin.
Where're you from?
martin924
PostPosted: Tue May 16, 2006 6:26 am    Post subject: Nottingham Reply with quote
Hi, im from Nottingham, managed to put a photo of the beauty on here on he right habd side, only had her a week and im loving every second!! There is a autokhana i think its called a classic car show near me at wollaton park, nottingham on the 4-6-06 Sun, ill take the kids to show them some real cars What a cool helpfull forim this is Thanks guys
PostPosted: Tue May 16, 2006 7:57 am    Post subject: Reply with quote
You have a 924 club in the UK as well.
http://www.porsche924owners-club.co.uk/
They do lots of shows.
chris24
PostPosted: Tue May 16, 2006 2:39 pm    Post subject: Reply with quote
Hey Martin. Welcome! Nottingham is a great place to live!
1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles)
seanski44
PostPosted: Tue May 16, 2006 2:49 pm    Post subject: Re: Nottingham Reply with quote
Might see you around
I'll be the one up and down the Derby Road between Stapleford and the town centre in my doom blue n/a !
p.s. just refitted my MD stereo, so the tunes will be good too
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
chris24
PostPosted: Tue May 16, 2006 2:51 pm    Post subject: Reply with quote
Sounds good seanski! Would be up for meeting after i get back on the 1st of June. Got that shell shifted?
seanski44
PostPosted: Tue May 16, 2006 3:06 pm    Post subject: Reply with quote
Yep, shell went on ebay for £90 they picked it up - 931 series2 shell with spare block, gearbox, all panels, most of the glass, five lug setup still on it and the turbo wheels and all the disc brake parts! - someone got a bargain if they have enough spare time and several wire brushes!
Will set up a meet when you're back - am off to the dyno on Sat, though my n/a is still not running as well as it could at least the dyno will help with where to start, as well as the chance to ogle some top modded/tuned 951 examples
(didn't intend to hijack this thread!)
1992 968 lux SOLD
