garyj19
Posted: Sat Apr 29, 2006 7:46 am Post subject: Fuel Accumulators. |
How important are the fuel accumulators? The linkage on the car to the fuel accumulators are very rusty and i have found that they are expensive to replace. Can i go without the fuel accumulators? Is there a way to do something else to replace these? thanks. _________________ early 77 924 na |
Posted: Sat Apr 29, 2006 8:03 am Post subject: |
You need them, the only way to get rid of them is to get rid of the CIS system. You could convert from 2 20cc ones to one 40cc unit. _________________ White 87 924S "Ghost"
D Hook
Keaton
Posted: Mon May 01, 2006 2:14 pm Post subject: |
| what do they do??? |
Posted: Mon May 01, 2006 2:24 pm Post subject: |
The accumulator/s is like a balloon in the fuel line.
The 'balloon' inflates when the pump is running and after shutdown, as long as the fuel system has no leaks or bad check valves, it keeps the fuel lines pressurised. _________________ Porsche 924 1984 (UK import) NA
Keaton
Posted: Mon May 01, 2006 2:29 pm Post subject: |
| why does it need pressure after it is off?? |
Posted: Mon May 01, 2006 5:41 pm Post subject: |
If the pressure drops the heat from the engine vaporises the fuel and you have a hot start problem.
The boiling point is raised by increasing the pressure. (common law of nature)
It keeps fuel at the injectors below opening pressure but high enough not to vaporise. _________________ Porsche 924 1984 (UK import) NA
garyj19
Posted: Tue May 02, 2006 6:12 am Post subject: |
thanks, i won it! now i hope it will work... _________________ early 77 924 na |
