Rear Wheel Bearings/CVs
isuras2
PostPosted: Tue May 02, 2006 2:07 am    Post subject: Rear Wheel Bearings/CVs Reply with quote
Wheel Bearings:
When reading the directions on how to install the wheel bearings, it says "make sure the chamfered edge faces out" or something to that effect. It looks like either face of the inner (ball) bearing could face out (from the center of the trailing arm). Same with the outer (roller) bearing. Any thoughts? The bearings I took out were SKF 6206/C3 (inner) and FAG 527539 (outer). I put new SKF 6206 ball and BCA roller bearings back in. Any thoughts?
CVs:
I need at least one new cv joint. Anyone know the best place (probably online) to find them?
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
