transmission drag
rdjohnston50
PostPosted: Sun Aug 13, 2006 9:27 am    Post subject: transmission drag Reply with quote
My 82 has been idle for 10 years. Now that I've got it running I've noticed the idle is slower with the clutch out and trannie in neutral. Is this normal? I suspect its just because the car hasn't been driven and the trannie oil (which is new) needs to be circulated. Throwout bearing on clutch does not make noise, so that must be ok.
Any ideas appreciated.
PostPosted: Mon Aug 14, 2006 1:36 am    Post subject: Reply with quote
they are all like this alittle bit, but shouldnt be more than about 50-100 RPMs and should catch itself and adjust for load
3 928s,
rdjohnston50
PostPosted: Mon Aug 14, 2006 2:02 am    Post subject: transmission drag Reply with quote
that's about what I see, a drop then correction. Thanks for the reply
