seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Mon Apr 17, 2006 11:40 pm Post subject: HELP. Rounded head bolt :( |
Hi,
Quick background - bought 931 as project with failed cam belt. I have a spare 931 head, so am attempting to get the head off and replace it (all being well in the block). All the exhaust is off and the Jpipe etc is all out of the way, air box and all pressure pipes are off. Am down to the head bolts themselves, but....
Car is an '81 series2 UK spec (RHD), it has the 'allen' style head bolts on it though, so its either never had the head off (can't believe that) or the bolts were reused (I'm assuming this as I'd imagine they should have been replaced with spline type bolts) One of the bolts (number 6 in the unscrewing order) was chewed before I got to it.. anyway, I assume that someone has screwed it up when torquing it back on, or has had a go at removing it in the past and failed (or both)- hence selling the car..
I put an 3/8" Hex bit in and attached my 18" torque wrench with an adapter. First, the bolt chewed the adaptor into two parts. I switched to the 1/2" hex bit (probably should have used this in the first place) and this time it rotated inside the bolt.
What's my next step? - any advice welcomed!
Arghhh, thought I've have the head off over Easter! (happy easter by the way) _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
-nick
Posted: Tue Apr 18, 2006 1:10 am Post subject: |
Are you using SAE sized allen/hex key sockets? The head bolts use a 10mm key (for the allen/hex heads). Try it again with the 10mm key.
If that doesn't work, you're going to have to just drill the head of the bolt off - very carefully without touching the engine head itself.
Also - never use a torque wrench as a regular wrench. It's a precision calibrated instrument. I would not trust yours to read the correct torque anymore. The head bolts are very sensitive to the correct torque.
Get a new 1/2" torque wrench, a 10mm allen key socket (snap-on makes a strong 3/8" drive 10mm socket, other's I've had have snapped), a 36" breaker bar to take the bolts off, and a new set of factory head bolts (along with the triple-square socket key for them) or a set of raceware studs/nuts.
Good luck!
nick |
seanski44
Posted: Tue Apr 18, 2006 1:22 am Post subject: |
| -nick wrote: | Are you using SAE sized allen/hex key sockets? The head bolts use a 10mm key (for the allen/hex heads). Try it again with the 10mm key.
Yes, I have a great set of allen/spline/torx bits. I used the correct bit as shown when the adapter broke. The hex bit is in perfect condition after both encounters, proving that the bolt was already pre-mangled.
| -nick wrote: |
I was worried this might be the only way...
| -nick wrote: |
OOpps, thanks, had to use it as it was the only wrench with enough leverage on it - I need to get a pry bar for my normal wrench, but worth knowing that the torque wrench isn't accurate any more as I've used it many times for tough jobs. Cheers.
| -nick wrote: |
Good luck!
nick |
Yeah, don't worry the head bolts were def gonna be replaced, I was just shocked to see what must be the original items there. - the hex bit I have is superb, a very good quality item, the 1/2 to 3/8 adapter I used was the one supplied with the torque wrench, so not nec a good item.
Any hints on drilling out the bolt? - slow drill or fast? Standard metal bit? what diameter?
any help gratefully received! _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
-nick
Posted: Tue Apr 18, 2006 1:37 am Post subject: |
Use a sharp drill bit, a little squirt of oil, and slow speed. You should be fine. The trick is - you won't be able to pull the head up off the remaining stud if the exhaust manifold is still attached. You can either try and grab the stud with vice-grips if there is enough sticking up, or you might have to drill a pilot hole into it with a smaller bit and get a reverse thread to twist it out. Maybe somebody else has another idea?!
Anyway, definitely replace that torque wrench. A 1/2" click torque wrench works great. Loosen it up to 2-3lbs of torque when you store it too - so the spring inside the wrench stays healthy.
nick |
seanski44
Posted: Tue Apr 18, 2006 4:12 am Post subject: |
| -nick wrote: | Use a sharp drill bit, a little squirt of oil, and slow speed. You should be fine. The trick is - you won't be able to pull the head up off the remaining stud if the exhaust manifold is still attached. You can either try and grab the stud with vice-grips if there is enough sticking up, or you might have to drill a pilot hole into it with a smaller bit and get a reverse thread to twist it out. Maybe somebody else has another idea?!
nick |
Cheers, a colleague of mine has just offered me use of his reverse thread bolt puller sets... hopefully these will do the trick! - Though I don't have much confidence in my ability to drill accurately... we'll see! _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
mustangporsche
Joined: 08 Oct 2003 Posts: 283 Location: California Lodi
Posted: Tue Apr 18, 2006 8:30 am Post subject: |
Well if you have a MIG welder you could tack a bolt to the head, than use a breaker bar with socket to get it off. Or just drill and use a easy out as someone else already said. Good luck, its not fun when stuff goes like this. _________________ 81 931
73 911 |
seanski44
Posted: Wed Apr 19, 2006 1:34 am Post subject: |
| mustangporsche wrote: | | Well if you have a MIG welder you could tack a bolt to the head, than use a breaker bar with socket to get it off. Or just drill and use a easy out as someone else already said. Good luck, its not fun when stuff goes like this. |
Cheers, neither got the welding kit, nor the necessary skills to use it!
will have a go with the removal tools and post on my progress... though haven't any time to do it for a couple of weeks  _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Posted: Wed Apr 19, 2006 2:29 am Post subject: |
My guess would be that a fully torqued head bolt won't come out with a bolt extractor as long as the bolts' head is still there. You'll be left with the extractor broken off in the bolt... I think you'll have to drill off the whole bolt head first, then use the extractor on what's left. A 12mm drill bit should center itself nicely and remove the whole head. That should leave you with a V in what remains of the bolt for centering the smaller sized drill hole for the extractor. _________________ "..it's made in Germany. You know the Germans always make good stuff."
bulldog fred
Joined: 03 Mar 2006 Posts: 13 Location: uk - portsmouth
Posted: Wed Apr 19, 2006 6:32 am Post subject: removing a headbolt |
hi lads i agree with the mig welding idea i have used on many things in the past and you know you are getting a result if you do a good weld!!, try other ways first if they do not succseed then you know it can be done this way if all else fails.... _________________ bulldog fred
1980 931 s1 silver
1982 931 s2 red - moded intercooler, water injection, avo sports suspension 944 turbo sway bars,green stuff brakes (brilliant) |
Posted: Wed Apr 19, 2006 9:20 am Post subject: |
Get the next closest sized allen wrench and file a slight taper into the front of it. Then jam it in the headbolt with a hammer. _________________ White 87 924S "Ghost"
nowivdunit
seanski44
Posted: Thu Apr 20, 2006 3:02 am Post subject: |
thanks guys, all good advice, will try the 'next size allen' method first.
Sorry, sears catalogue link didn't work for me so I haven't any idea what you suggested!
as for the mig welding, well, that will be last resort as it'd mean giving in and paying for the car to be trailered to someone who could do that... _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
nowivdunit
Posted: Fri Apr 21, 2006 12:39 pm Post subject: |
I have a set of those and they are awesome! I don't know if there is enough space to use them on headbolts however. _________________ White 87 924S "Ghost"
Posted: Fri Apr 21, 2006 2:18 pm Post subject: |
actually once the head of the bolt is removed/drilled off it will be very easy to remove the rest of the bolt, as the washer which should be under it should leave enough of a grip for needle nose pliers to turn it. and once the head is removed all torque is removed from the bolt and it should turn with ease. _________________ 3 928s, |
