horsleyflyer
Posted: Mon Mar 27, 2006 5:26 pm Post subject: Oil Pressure Down |
Hi Folks,
The oil pressure on my standard 1984 924 has just dropped to a little over two bar at 3000 RPM. I was previously getting about one bar per thousand rpm. I'm assuming the usual suspects of oil pressure sender, oil pick up in the sump and oil pump. The car has covered a little over 140k and is not burning any significant amounts of oil. Could any of you give advice please ?
Thank you very much
HorsleyFlyer |
Posted: Mon Mar 27, 2006 5:47 pm Post subject: |
Bad oil filter, broken or cracked oil supply tube plastic elbow on the cylinder head, or defective oil pressure sender or wiring.
Posted: Mon Mar 27, 2006 6:06 pm Post subject: |
electrical connections/grounds? _________________ 1979 924 (Gone to a better place)
Tigger937
Posted: Mon Mar 27, 2006 6:13 pm Post subject: |
| Peter_in_AU wrote: | | electrical connections/grounds? |
Does the oil pressure indicator move as the intensity of the dash lights dimmer switch is varied when headlights are on? _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
horsleyflyer
Posted: Tue Mar 28, 2006 7:20 am Post subject: oil pressure down |
Hi There,
Thanks for the ideas i'll go and check. The needle appeared to be showing a good pressure on start up and then flickerd and went down to two bar. I'll have a look at all the things you've suggested and get back.! |
Posted: Tue Mar 28, 2006 9:51 am Post subject: |
Also check the pressure relief valve (located on the oil pump). _________________ White 87 924S "Ghost"
horsleyflyer
Posted: Fri Apr 14, 2006 5:37 am Post subject: oil pressure down |
| Thank you all for your help. It was the the oil pressure guage earth, which I renewed and got an extra two bar ! |
