Chrenan
Posted: Sat Apr 08, 2006 7:44 am Post subject: Confirm TDC by Valve Position - Picture Included |
Hi Guys,
Just want to make sure I have things close to correct before I join the head to the engine.
Does the following picture look right for TDC? Front of the head is left.
 _________________ 1987 951 - M193 Version for Japan |
Posted: Sat Apr 08, 2006 8:08 am Post subject: |
You have a NA, so it doesn't matter. If you are worried, put the cam gear and valve cover on and line up the marks. _________________ White 87 924S "Ghost"
Posted: Sat Apr 08, 2006 8:11 am Post subject: |
Looks like you're actually at TDC and ready for spark on cyl 4 there. Since the firing order is 1-3-4-2, if you were at TDC for #1, with #3 next to fire, then #3 should have its' intake valve opened, but that's not the case - #2s' intake is opened and would be ready to fire next, so #4 is at TDC there. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Chrenan
Posted: Sat Apr 08, 2006 8:46 am Post subject: |
Cam gear is from a early car and I actually can't see any marks on it like on my 1980. Maybe there is a paint mark that has since been wiped off.
Smoothie, that makes sense to me.
I think I'm going to yank the cam gear off my 1980 and throw it on this head, I don't like having no markings. _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Sat Apr 08, 2006 10:34 am Post subject: |
OK, think I got it figured, thanks for the quick help guys. Turns out the marker on the earlier cam sprocket is a bit smaller than the one on the 1980 version. I should have been wearing my glasses!
With the arrow and the marker on the cam sprocket lined up, I get the following, which definitely makes more sense:
Posted: Sat Apr 08, 2006 10:37 am Post subject: |
Yep, that's it! _________________ White 87 924S "Ghost"
