low volts and sometimes erratic Voltmeter
seanski44
PostPosted: Wed Apr 05, 2006 4:52 pm    Post subject: low volts and sometimes erratic Voltmeter Reply with quote
hi all,
Quick query - I have had a problem or two recently, (posted here) concerning electrics, first a burned out loom, the front harness to the alternator and starter motor (replaced with a brand new part) and second in the earths from the cold start gear, causing the car to be permanently 'on choke'
Anyway, the background to one side, now those probs are fixed, the car runs fine (and Volts at about 13V constant), but on the last few drives the voltmeter was constantly about 11V. Occasionally it'll go above 12V and behave erratically. Car still seems to run OK, but lights slightly dimmed. Revving engine doesn't seem to increase Volts. Alternator belt is only a thousand miles old. Turning on indicators makes the Volt meter 'tick' in time with them in the same way as it used to, just lower down the scale!
My q, is this indicative of a dying alternator? or could it be more bad earths?
What's the easiest way to check.
TIA
Sean
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
PostPosted: Wed Apr 05, 2006 5:21 pm    Post subject: Reply with quote
Make sure you have a good earth from the alternator to the motor and from the battery to the motor.
Another common problem is the brushes in the back of the alternator wear out. This is a black box screwed onto the back of the alt and holds the brushes and is a common bosch part found anywhere.
PostPosted: Wed Apr 05, 2006 7:32 pm    Post subject: Reply with quote
there's been a lot written about the voltmeter.
Basically, the way Porsche wired it it's really just a bit of eye-candy after all these years. The problem is that all it reads is the voltage in the wires connected to the surrounding instruments.
If you want an accurate reading you need to run some wires from the voltmeter to a chunky switched cable electrically close to the battery. Have a look at the current-flow diagram and you'll see what I mean.
The voltmeter dancing in time with the indicators is a standard feature that stops you getting bored while waiting to turn. Remember these cars were made before electro-luminscent CD head-units.
The dimmed lights are probably an earthing issue.
seanski44
PostPosted: Wed Apr 05, 2006 7:47 pm    Post subject: Reply with quote
...The voltmeter dancing in time with the indicators is a standard feature that stops you getting bored while waiting to turn. Remember these cars were made before electro-luminscent CD head-units.
He he he.. I've always enjoyed the dancing needle...
On the more serious note though, its not the dancing needle that worries me, its that its now dancing at a lower part of the dial! - anyhow, I won't worry too much about it for the mo, and may try to check the Voltage somewhere relevant at another time!
EDIT: - my mention of 'erratic' was to do with it sometimes being above 12V and most of the time not... rather than confusing it with the dancing needle when indicating. (or in olde englishe 'operation of the trafficators')
Cheers for the speedy replies.
1992 968 lux SOLD
seanski44
PostPosted: Wed Apr 05, 2006 7:48 pm    Post subject: Reply with quote
The earth 'should' be perfect, as that loom part is brand new... maybe I'll check the connection to the alternator itself in case its worked loose or something.
Otherwise the brushes sound a good call. do I have to remove the alternator to check them?
1992 968 lux SOLD
PostPosted: Wed Apr 05, 2006 10:18 pm    Post subject: Reply with quote
Why would the earth be perfect. The only wire in that loom that went to the alt. was the red +.
On the alt itself is a large braided wire connected to the block or should be.
I think you would have a hard time gettting to the back of the alt without removing it.
D Hook
PostPosted: Wed Apr 05, 2006 10:57 pm    Post subject: Reply with quote
Have you read the battery voltage at the battery with a DVM? What's that read?
Clean every ground you can find, especially above the fuse panel. Unplug and replug everything to scrape off any corrosion on the gauges, including the fuel/temp gauge.
You'll be amazed how much better the car will run, too.
'80 924 n/a SOLD
seanski44
PostPosted: Thu Apr 06, 2006 12:19 am    Post subject: Reply with quote
Cheers, no, I actually don't own any kind of volt meter except for the one in the n/a and the one in the 931 P - hmmm, OK I could get myself one after payday, but what about 'borrowing' the one from the 931 and using that to check the n/a? whaddaya reckon? Waste of time?
1992 968 lux SOLD
D Hook
PostPosted: Thu Apr 06, 2006 2:50 am    Post subject: Reply with quote
You might want to buy an inexpensive one that is meant to read DC volts and has leads on it. It's probably a good tool to have for any owner of these cars.
Also check the connections on the firewall that are part of the mounting bracket for the coil. There's usually a ground that hooks there, too.
Clean every ground you can find, shine them up so you get a good solid connection. Then the plugs to all the gauges. Condensation in the cabin from water leaks will cause corrosion on them and the connections will start to fail.
Good luck!
'80 924 n/a SOLD
PostPosted: Thu Apr 06, 2006 8:12 am    Post subject: Reply with quote
I've heard bicarb/soda works well on copper corrosion.
PostPosted: Thu Apr 06, 2006 8:34 am    Post subject: Reply with quote
Run a 12 gauge or larger stranded copper wire (some people use battery cable) from the alternator case to the engine block, and then, another piece of the same cable from the engine block to the chassis. Soldered terminals on the cable ends will give you the best electrical connection. Clean the mounting hardware you use, and spray an anti-corrosive chemical (made for use on battery terminals) on the hardware before assembling, and again over the top when the connections have been secured. Make sure that the battery cable that connects from the battery to the chassis is in excellent, uncorroded condition.
The little black plastic box on the back of the alternator that contains the brushes is actually the voltage regulator for the alternator. Sometimes they go bad, and a replacement is not included with rebuilt alternators. You buy them separately, so you could try buying a new one and installing it to see if it cures your problem. The brushes that are part of the voltage regulator are not replaceable. When the brushes wear out, the voltage regulator needs to be replaced. If you suspect that the voltage regulator is bad, you could try getting a complete alternator from a salvage yard. At the local Pick A Part salvage yards, you can buy a complete alternator for less than the cost of a voltage regulator at the FLAPS.
PostPosted: Thu Apr 06, 2006 9:40 am    Post subject: Reply with quote
seanski44 wrote:
...no, I actually don't own any kind of volt meter except for the one in the n/a and the one in the 931...
Just a tip, I got a digital multimeter from the local el-cheapo auto store for about ten bucks Aussie. OK, it's not the best one in the world, obviously. But it's fine for using on a 12-volt system in a car.
Similar to this:
PostPosted: Thu Apr 06, 2006 10:26 am    Post subject: Reply with quote
The volt regulator/brush gear only cost about $30au last time I bought one.
Was a while ago though.
PostPosted: Thu Apr 06, 2006 12:01 pm    Post subject: Reply with quote
Complete used alternators are $20 at Pick A Part yards here.
PostPosted: Thu Apr 06, 2006 3:03 pm    Post subject: Reply with quote
Bugger- lucky to get away with $50 here. and then you'd still have to replace the bearings or brushes
