Clutch bellHousing Help
bass gt
PostPosted: Wed Mar 29, 2006 2:02 am    Post subject: Clutch bellHousing Help Reply with quote
Guy's,
i am trying to remove the bellhousing from my spare engine, but seem to be having a bit of bother. I cannot seem to remove the lever shaft. I have run an M8 stud into it and used a puller, but with no joy. Am i missing something obvious??
thanks,
Steve
PostPosted: Wed Mar 29, 2006 2:24 am    Post subject: Reply with quote
Haven't had to do it yet myself, but it sounds like fun. Not!
Looks like you need to use a slide hammer. Have a look here - http://www.924board.org/viewtopic.php?t=11041
-nick
PostPosted: Wed Mar 29, 2006 3:27 am    Post subject: Reply with quote
If the spare motor is out of the car, you can pull the pin out that covers the top of the shaft, then use a metal punch/rod and beat the shaft out from the top. Or use the slide-hammer method from the bottom. You can often borrow them from your local generic auto parts joint.
Squirt some PB Blaster down in the hole from the top too. The shaft can really cement itself in there.
nick
bass gt
PostPosted: Wed Mar 29, 2006 5:37 am    Post subject: Reply with quote
Slide hammer eh?? Hmmmm.
I get visions of it all going horribly pear shaped (wrong) once you leave the safe confines of engineering and enter the realm of brute force and ignorance!!!
So i guess once the lock nut is removed, it is just a case of give it hell.
Cheers guy's, i was worried i was missing something really stupid!!
Steve
numbbers
PostPosted: Wed Mar 29, 2006 11:39 am    Post subject: Reply with quote
Follow the Haynes, and use a slide hammer. I used an el-cheapo slide hammer from a body repair kit, but replaced the sheet metal screw with an 8mm screw. You will have to wak it hard several times, but it will pull straight out.
Kenodog
PostPosted: Wed Mar 29, 2006 2:05 pm    Post subject: Reply with quote
Because the shaft is steel and the housing is aluminum when it gets moist it causes galvanic corrosion.The ions of the lesser material bind with moisture to form a substance I like to call Crud. Crud acts like glue.Hence your current problem.
When you replace the shaft with a new one make sure you put a coating of anti-seize on it and you shouldn't have this trouble the next time.
My $.02
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
ic932
PostPosted: Fri Mar 31, 2006 6:04 am    Post subject: Reply with quote
If the slide hammer does'nt work (and this has happened to me before), all is not lost. Simply undo the nine pressure plate allen bolts through the stater motor hole and then remove the bellhousing complete with clutch assembly. Remove the circlip in the release bearing and lift out the pressure plate......now you will have access to cut the shaft a cm either side of the siezed (frozen) area where the shaft has binded to the alloy bellhousing. Simply punch the remaining pieces out of the bellhousing. Tedious method but better than a cracked bellhousing due to over zealous hammering.
Dave.
Benino
PostPosted: Fri Apr 07, 2006 7:48 am    Post subject: Reply with quote
I had one that was really stuck. I Used a combination of pulling on the bottom and pounding it through from the top.
With the engine out of the car you can use a long bolt to pound it out from the top. There is a pin that keeps the lever rod from being pushed in too far when you install it from the bottom. It only blocks about 1/2 of the top end of the rod. I got a long bolt, put it in through the hole on the top against the exposed part of the top of the lever rod and pounded down with a sledge. It came out.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Fri Apr 07, 2006 8:58 am    Post subject: Reply with quote
Someone posted recently that you can also remove the starter then remove the pressure plate bolts through the hole. After this the bell housing can be removed, but be ready to catch some heavy parts!
White 87 924S "Ghost"
bulldog fred
PostPosted: Wed Apr 12, 2006 3:54 am    Post subject: bellhousing removal Reply with quote
steve if you haven't done it yet i have stripped a few down now and none of them come out with just the 8mm stud you have to use brute force from the bottom opening once you locate the pin the rod stops against there is plenty of room for a small drift to fit either side of the end pin and then bring out your enforcer and the job should be done !!!!!regards -fred
bulldog fred
1980 931 s1 silver
1982 931 s2 red - moded intercooler, water injection, avo sports suspension 944 turbo sway bars,green stuff brakes (brilliant)
