YEA! I rebuilt the wiper moter. Got 1 question please
rad99
PostPosted: Sun May 21, 2006 4:26 am    Post subject: YEA! I rebuilt the wiper moter. Got 1 question please Reply with quote
Rust, rust, rust....O.K. its perfect now and running on test just fine.
So, should I apply a silicone sealant to rim and where screws go to prevent moister from getting back in?
77 924 n/a
Silver w/black int.
5 speed
PostPosted: Sun May 21, 2006 8:07 am    Post subject: Reply with quote
cant hurt
rad99
PostPosted: Sun May 21, 2006 10:00 am    Post subject: Reply with quote
Thanks. Wiper motor installed and working, just removed steering wheel, going to attempt cleaning wiper switch if I can find the 2 elec plugs at rear.
77 924 n/a
Silver w/black int.
5 speed
rad99
PostPosted: Sun May 21, 2006 11:51 am    Post subject: Reply with quote
Cleaned contacts for wiper switch. Now I popped out the speedo,
Like the haynes manual says,( I thought I had to remove dash to get to speedo) and Now I will find tech on speedo repair. I am a happy camper and would NEVER be able to accomplish any of this without YOU GUYS and all the posts I have searched. Again, thank you!
77 924 n/a
Silver w/black int.
5 speed
PostPosted: Sun May 21, 2006 1:19 pm    Post subject: Reply with quote
If you have the classic broken odometer then this is the best repair guide I know of http://www.pelicanparts.com/techarticles/Mult_gauge_repair/mult_gauge_repair.htm
If your odo is OK then bookmark the article anyway, you will probably eventually need it.
rad99
PostPosted: Sun May 21, 2006 1:50 pm    Post subject: Reply with quote
Thanks but I just glued and put back together. The little white wheel had moved over enough to no longer engage with the larger wheel so I pulled it out and through some glue on there. Not sure how long it will hold. I will get what you have suggested in case I have to repeat this.
77 924 n/a
Silver w/black int.
5 speed
