fergie
Posted: Wed Mar 15, 2006 6:08 am Post subject: where to get new copper washers |
According to haynes every time you reassemble banjo fittings in the fuel system, new copper washers are to be used...
Where are we supposed to get all these new copper washers?
Ive tried the hardware store, auto parts store, and have looked around on several websites without finding any that will work.
And ive got two banjo fittings that are leaking because ive reused my washers. _________________ 1996 Honda del Sol Si Turbo
1977.5 Porsche 924 (for sale) |
Tigger937
Joined: 11 Apr 2004 Posts: 919 Location: PCA Milwaukee Region
Posted: Wed Mar 15, 2006 6:15 am Post subject: |
SpecialTauto.com is one source. Another might be a VW dealership. Can't be that expensive. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
fergie
Posted: Wed Mar 15, 2006 6:44 am Post subject: |
wow thanks for that website...
just to be sure... do i need the 8x11.5 or 8x13 mm washers? _________________ 1996 Honda del Sol Si Turbo
ATL_racer
Joined: 09 Aug 2005 Posts: 97 Location: Atlanta, GA USA
Posted: Wed Mar 15, 2006 6:48 am Post subject: |
i got new copper washers for my fuel injectors, i bought them from the porsche dealership for 79Cents _________________ late 1979 porche 924, red 2.0l NA 5speed snailshell
Plans: Restore exterior, revitalize interior, install killer sound system, run engine in stock form and have fun.(+ a short throw shifter if i can find one) |
Tigger937
Posted: Wed Mar 15, 2006 7:12 am Post subject: |
Most of the fuel systems' sealing washers are actually aluminum. In the parts lists, a description starting with "A" indicates aluminum. "A 8 x 11,5" would be for an aluminum sealing ring with 8mm ID and 11.5mm OD. Maybe no problem replacing with copper, but originally they'd have been alumin[i]um.
The copper sealing ring for the oil drain's designated with a C as "C 26 X 32". _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Mar 15, 2006 7:29 am Post subject: |
Try a fuel/tune up place. _________________ Porsche 924 1984 (UK import) NA
Tigger937
Posted: Wed Mar 15, 2006 7:39 am Post subject: |
| Smoothie wrote: | Most of the fuel systems' sealing washers are actually aluminum. In the parts lists, a description starting with "A" indicates aluminum. "A 8 x 11,5" would be for an aluminum sealing ring with 8mm ID and 11.5mm OD. Maybe no problem replacing with copper, but originally they'd have been alumin[i]um.
The copper sealing ring for the oil drain's designated with a C as "C 26 X 32". |
Smoothie, you make a very good point. The following link shows Al & Cu to be on opposite ends of the galvanic chart, which is a bad thing over time.
http://www.thelenchannel.com/1galv.php _________________ 1981 931 (Concours)
