Slam
Joined: 07 Jan 2005 Posts: 1689 Location: Wainwright, Alberta, Canada
Posted: Wed Mar 08, 2006 1:53 pm Post subject: Oil pressure gauge wiring? |
Guys, can I run an oil pressure gauge on a 77.5 924 using the existing oil pressure switch? I suppose I could just go out and look at the switch and count the contacts, but this is warmer
The 931 pull-apart is going slowly but surely. I'm hoping for some decent weather - it sucks pulling cold wrenches. And I may try to get a camera so you can all look over my shoulder at the goings on. And on. And on...
Thanks in advance for an answer to A) above. _________________ '84 944 - kid blew motor
'83 944 - resting comfortably. For 12 years
'87 944 - sideswiped by trucker
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably |
Posted: Wed Mar 08, 2006 7:36 pm Post subject: |
If the car originally came with a gauge, it would have the combo oil pressure light switch + pressure gauge sender. If not, it would only have the pressure switch. Might as well take a look, but you should find it's the single function switch. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Slam
Posted: Thu Mar 09, 2006 3:40 am Post subject: |
Thanks, smoothie,
If I find the single-function pressure switch, I should be able to replace it with the dual-function one and fun the gauge, no? The location and threads will be the same? _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
Posted: Thu Mar 09, 2006 4:14 am Post subject: |
Yes, same location and I'd have to give it a 99.999% certainty that they're the same thread size. It just wouldn't make sense for them to use different sizes on those pieces.
Fun-easy project for when the engine (or at least the head) is out of the car - virtually to literally imposible otherwise - http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=bdb3&.dnm=a835.jpg&.src=ph _________________ "..it's made in Germany. You know the Germans always make good stuff."
Tigger937
Posted: Thu Mar 09, 2006 4:44 am Post subject: |
Yeah, you're right about that Smoothie! I'm working in that area now, with the head on and engine in place. My engine wiring harness needed repair/re-routing, so I've had to remove it. To get at the thermo-time switch, I've had to remove the dizzy and housing and coolant flange housing the thermo-time switch and temperature gauge sender. Then things become more accessible. Patience required! _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Slam
Posted: Thu Mar 09, 2006 6:39 am Post subject: |
Arrgh. I'm not yanking another engine...
Thanks, guys. _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
