Tensioner slipped
PostPosted: Fri Mar 10, 2006 2:04 pm    Post subject: Tensioner slipped Reply with quote
I dont torque it down enough .. I guess And its snowing today and its 6am & Im on my way to work 75 miles one way to a union carenter job ( Im
a 6 term apprentice thats 82% journeyman wage.. Im getting training also from the jatc all I need is about 1000 more hours & Ill turn journeyman) also specializing in eis.
Traffic is going really slow cause Im in one part of the valley where it gets cold & theres frozen snow around Im so bored I let the car ahead go then gun my motor spinin out
& shiften into 2nd and spinin some more...
I notice my belt starts whining
but make it to work not having any tools I decide to just go home soo ..
at about the same spot my car dies the cam belt teared off all its teeth enough to jump timing I get home while replacing the belt I
decide to pull the alt & check the bushings & rubber mount since I had to jack the front up ( one side) & pull the belly pan ... You think alls good not soo. the tensioner bolt came out with alot of threads wrapped around it I didnt have time today or friday to retap the hole so I used this stuff ..
http://www.gorillaglue.com/ on the bolt and then on the bolt and tensionercontact point ( this glue you moistin the part with water then apply glue and over time the glue swells doubling in size. It worked.
moone924
PostPosted: Sat Mar 11, 2006 2:17 am    Post subject: Reply with quote
I use to have that problem with timing belts.... the teeth cutting off etc....
I found that I had too much tension on it.
Ryan Moone
New philosophy : one car project at a time.
flosho
PostPosted: Sat Mar 11, 2006 3:32 am    Post subject: Reply with quote
Be happy its not interference.. My car has slipped it 2 times within 500 miles!
You have some great maguiver skills!
[This Space For Rent]
Tigger937
PostPosted: Sat Mar 11, 2006 3:42 am    Post subject: Re: Tensioner slipped Reply with quote
Holy smoke. That must be some pretty tough glue!
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Sat Mar 11, 2006 2:36 pm    Post subject: Reply with quote
yea it worked i put 150 miles on it today.
