924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Mon Jun 02, 2008 4:29 pm Post subject: My 924 is slow... |
im just going to have to open a thread because i am bored and i feel like i have to let this out
i know the old 924 na cars are low performance but its really that BAD!
i dont know about you folks but my car is so slow i cant even keep up with regular traffic! i mean, nothing is wrong with it or anything, i have a rebuilt head, replaced all the bad gaskets and i felt a little more power before. but i mean this is REALLY slow, i mean how the is it 2.0 when i drive a 1.6 its a big difference but thats probably because of the weight. the worst part is accelerating... from 1 to 2 until 3 gear everyone behind me is trying to pass me until i reach 55 mph... here is america we drive pretty fast compared to other countries with smaller roads. is this just normal for a 924 or is it just mine? anyone feeling the same way???... maybe ill feel much better _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
Posted: Mon Jun 02, 2008 4:47 pm Post subject: |
maby you're driving slow  _________________ Supercharger and EFI kits
924er
Posted: Mon Jun 02, 2008 5:33 pm Post subject: |
yea thats what i thought, but i shift at 4000rpm and i still cant keep up with traffic, most cars accelerate nice at 3000rpm or thats what i noticed...
when i have two people or just one fat dude, my foot is nearly floored and i still cant keep up with traffic! _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Mon Jun 02, 2008 6:06 pm Post subject: |
1. vacuum advance isnt doing the job
2. low fuel pressure.
3. vacuum leaks.
4 blocked crankcase breather
5 blocked fuel filter
6. blocked air filter
7 valve timing wrong
8 valve clearances wrong
9 ign timing wrong
10 air/fuel mix wrong
11 any combination of the above. _________________ Porsche 924 1984 (UK import) NA
924turbo_sout_africa
Posted: Mon Jun 02, 2008 8:05 pm Post subject: |
ya it's only you that is feeling that my buddy got him a 924 on sunday only told me know and i think it's a 79 ...and let me tell you it aint slow at all .....
o ya if you think the americans drive fast you should come try the sout africans i was in america last year hell i was so frustrated in traffic there people sleep at the lights. _________________ Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !! |
RC
Posted: Mon Jun 02, 2008 8:43 pm Post subject: |
12. Location: Los Angeles California
12.1 low compression
12.2 smog pump
12.3 cat (blocked or not)
12.4 low octane fuel
12.5 retarded stock ignition timing
12.6 cis tuned to comply with ultra conservative regulations
12.7 low atmospheric O2
13. but i shift at 4000rpm
Roger |
Joined: 29 Jul 2001 Posts: 9136 Location: Royal Oak, MI, USA
Posted: Mon Jun 02, 2008 10:40 pm Post subject: |
Sounds slower than it should be; time to work through all the tune-up stuff listed, and I'd suspect that you may have a bad warm-up regulator... _________________ Vaughan Scott
Chrenan
Posted: Tue Jun 03, 2008 12:29 am Post subject: Re: My 924 is slow... |
| 924er wrote: | | My 924 is slow... |
Mine's not.  _________________ 1987 951 - M193 Version for Japan |
924er
Posted: Tue Jun 03, 2008 2:31 am Post subject: |
ok i never checked the fuel pressure before,
ah man so its only me then ####!
im sure there is not any vacuum leaks i replaced most hoses
new fuel filter
new air filter
the valve timming was also done as well as the ignition timming
and the fuel and air mixture was adjusted by the smog person maybe it's off,
and no i dont think i have a warm up regulator problem, my car always starts up hot or cold.
and i have a cat of coarse i live in california!
i usually pump the regular octane fuel what about you guyz?
next i will check the compression, what should the compression be for a car like mines? _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Tue Jun 03, 2008 3:52 am Post subject: |
| 924er wrote: |
Then I don't think you understand what this part does.
To check it you will need the control pressure checked either by borrowing the gauges from someone and comparing hot and cold pressures with the charts in the Haynes or factory manuals, or have a garage that knows CIS check it.
You should also check your fuel injectors for good spray, and run some Chevron FI cleaner through it. _________________ Vaughan Scott
cgalyon
Joined: 05 May 2008 Posts: 249 Location: Knoxville, TN
Posted: Tue Jun 03, 2008 4:31 am Post subject: |
I run higher octane (92) fuel in my car (it asks for 91 or above) and it makes a noticeable difference in pick-up. Not sure if the NA's ask for higher octane as well (maybe it's just an S thing), but on older cars it's usually worth a try. It is a minor boost, though, unless your car has built up a lot of gunk in the fuel system from having lower grade gas running through it for too long (and then you should clean it out and use higher octane). _________________ 1988 924S Navy Blue - Phone Dials |
924er
Posted: Tue Jun 03, 2008 6:01 am Post subject: |
ok nvm i dont know what a warm up regulator is! lol
does it have to do something when my car starts up it idles really low but still runs normal until its fully warm then the idle just stays at 1000rpm??
yes i used the chevron fuel injection cleaner after i rebuilt the head and it did make a difference but its still slow..
i will ask around to see if any garage knows how to play with CIS
i dont think my car is giving me it's fullest _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Tue Jun 03, 2008 6:33 am Post subject: |
The block labelled "WUR" here represents the warm-up regulator (it's aka- "control pressure regulator") - http://www.flickr.com/photos/9754161@N02/739763746/in/set-72157600685476130/
This one shows the WUR internally - http://www.flickr.com/photos/9754161@N02/2299225602/in/set-72157600685476130/
In a sentence, it regulates control pressure by bleeding off fuel pressure from above the fuel distributors' control plunger to affect the air:fuel mixture, providing a richer mix when cold and leaner mix when warm.
-So it has to be functioning correctly, not only for warm-up, but also for normal running afterward. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924er
Posted: Tue Jun 03, 2008 8:47 am Post subject: |
oh i see those are good illustrations smoothie,
i did a search on how much those things cost and its about $300!!
so the WUR can affect your horsepower? _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Tue Jun 03, 2008 9:39 am Post subject: |
Have you checked to make sure your throttle is wide open when the gas pedal is floored? _________________ White 87 924S "Ghost"
