geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Mon Feb 27, 2006 11:30 am Post subject: Only one cylinder firing |
Only one of my cylinders is firing yet they all have compression and fuel and spark. I even tried adding starting fuel to them and still only the one is starting. I have even checked the firing order three times. What do you all think is the problem is? _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
alxch1n15
Joined: 26 Nov 2004 Posts: 261 Location: Madison, Wisconsin
Posted: Mon Feb 27, 2006 11:48 am Post subject: |
i remember watching a kids in the hall episode where a neighbors kid was in the engine, and the car wouldnt start because of that: so check for your neighbors kid...
sorry i can help more, but are there any other symptoms? _________________ '81 924 n/a |
Posted: Mon Feb 27, 2006 4:30 pm Post subject: |
If all the cylinders have fuel, and spark at the right, time, then all the cylinders would be wiring.
Obviously you are missing something or assuming something.
You need to go back and check and verify everything you just wrote that was okay.
Fuel, Spark, and Timing at every cylinder. |
geddes66
Posted: Tue Feb 28, 2006 3:41 pm Post subject: |
Son posted #1 post on this string on my behest, he now has his own screen name.
Found the problem! It is good news.
problem part #1: Brain vaporlock preventing simple tests.
Problen test: Move plug wire from only firing cylinder to another cyl.
POOF! Other cylinder fires. It's the plug wires!! (ordered yesterday)
BTW Cyl test: cold, cold, OUCH, cold.= #3 firing _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Sat Mar 04, 2006 2:40 am Post subject: |
yea i had a similar problem which was really making me mad. my first cylinder would only run sometimes, and you can hear when its running because there is a ticking noise. so i changed the sparkplugs, it fired more frequently, then later changed my leads and now its has never stoped firing since then _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
