Bolting on a supercharger
doomer77
PostPosted: Sun Feb 26, 2006 12:33 am    Post subject: Bolting on a supercharger Reply with quote
me and a friend is having a disagreement, he says that it is entirerly possible to bolt on a supercharger or turbo on an engine without doing any mods to the engine and everything will work. I think that doing this will completetly kill the engine very quickly due to very excessive wear.
who of us is right?
(not only regarding 924 engines..)
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
chris24
PostPosted: Sun Feb 26, 2006 1:21 am    Post subject: Reply with quote
Well, depends on how sound your engine is to start with. Will a 200,000 mile knackered engine stand it? Possibly not!
Look at what ESC944 is doing. Lots of interesting stuff in those 6 pages.
http://www.924board.org/viewtopic.php?t=15547&postdays=0&postorder=asc&start=0
(edit) Quoted from ESC944
Quote:
The design concept is a complete kit you could install in a day or a weekend and a six pack of beer...
No Welding, is a key concept.
That doesnt fit into my idea of plug and play.
Simply put no welding.
No cutting that I can see or imagine.
Drilling is a real possibility, but only from the perspective of mounting support ware, etc.
Ideally I will try to find ways to allow you to mount everything using existing points on the car, etc...
1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles)
PostPosted: Sun Feb 26, 2006 2:11 am    Post subject: Reply with quote
You'd also want to provide some form of anti-detonation protection as in fuel enrichment and/or water injection, intercooling, timing retard...
PostPosted: Sun Feb 26, 2006 5:52 am    Post subject: Reply with quote
It depends on WHAT engine...and in what condition the engine is.
the 924 NA engine can handle some boost.
NOTE: US cars have lower CR....we have 9.3:1 CR...
CBass
PostPosted: Sun Feb 26, 2006 8:08 am    Post subject: Reply with quote
Yes, it is very much dependent on the condition of the engine and the engine in particular.
Many engines can accept a bolt on supercharger kit, most kits come with everything you need including a chip that modifies the fuel and ignition to suit the new characteristics of a forced induction engine. GM makes one for Cavaliers and Sunfires with the Ecotec engine, I think they even install it under warranty but I'm not 100% on that. Comptech makes them, Jackson Racing, just to name a few people making bolt on blowers for 4 cylinders.
The 924 is not nearly so simple, the fuel and ignition systems must be recalibrated, or you'll be in trouble.
If you have an engine which has bad rings, fuel injection system in dodgy working order, carbon deposits and such, you're really rolling the dice trying to increase cylinder pressure with forced induction, or combustion force with nitrous or the like. If you don't get enough fuel, you'll run into detonation. Even if you don't experience detonation, you may burn your pistons or valves from combustion temperatures which are too hot. Carbon deposits can also stick valves causing backfires into the intake, as well as detonation.
Rigging up a forced induction system for an engine like the 924 is something best left to someone who is very knowledgeable and experienced in forced induction applications. Luckily we have a board member who is just that, ESC944. Read the thread Chris linked.
J1NX3D
PostPosted: Sun Feb 26, 2006 8:38 am    Post subject: Reply with quote
I drove Andrew NZs 4spd euro n/a for about 2hrs out of a 5 hour trip back to Auckland after Targa NZ. The engine was incredibly tired and it was hard work.
I went for a quick ride in it last week now rebuilt with the bae, its a totally different animal. IT_IS_ SERIOUSLY_QUICK!! IMHO It would eat my stock turbo off the line! I cant wait till he works the bugs out of the system!
'86 944
