bob
Joined: 16 Mar 2005 Posts: 17 Location: Douai, north of France
Posted: Fri Oct 28, 2005 8:16 pm Post subject: clutch play....how to adjust??? |
Hi,
last time i've changed my clutch. But now, i've got a problem with the clutch play adjsuting. I know that the hydraulic clutch can't be adjusted, but when the turbo blow (at least 3000 rpm), the clutch run over.... where is the problem?
In normal use, i can drive with it, but the problem is present at an accélération after 3000 rpm.
thanks fot your help.  |
Posted: Sat Oct 29, 2005 12:48 am Post subject: |
The hydraulic clutch is self-adjusting, but there is an adjustment at the pedal (to be sure the piston in the master cylinder retracts fully when the pedal is released). You should have 0.5mm freeplay at top where the pedal rod contacts the master cylinder - and 3.0mm freeplay down at the pedal pad. To adjust, there's a nut on the rod that needs to be loosened, then you'd turn the rod in or out to adjust, then tighten the nut again.
Of course it's possible that the clutch is fine and what you're feeling is actually something like a loss of power due to some other problem, but you might as well check the clutch pedal adjustment first. _________________ "..it's made in Germany. You know the Germans always make good stuff."
bob
Posted: Sat Oct 29, 2005 4:43 am Post subject: |
OK smoothie, thanks for your help.
this afternoon, i've turned the nut to adjust it. I 'll test it this sunday: we have a meeting with the 911 club of tourcoing...
thank's  |
bob
Posted: Sun Oct 30, 2005 3:54 am Post subject: |
Well, after tryed to adjust the clutch play, i think my clutch wrecked...
i had changed it , it was a second-hand buy, but it looked like ok: good thickness, good springs etc, perhaps the diaphragm spring....
for the time, i will drive with it. i can drive, but i can't speed up violently, 'cause the engine roll over
it's time to save money... |
Posted: Sun Oct 30, 2005 4:21 am Post subject: |
If you need to replace the clutch disc again, you can save money by getting one for a Ford Bronco II. They're the same size at 8-7/8", 1"x 23 spline hole. Look here - http://www.924board.org/viewtopic.php?t=10723&start=0 _________________ "..it's made in Germany. You know the Germans always make good stuff."
bob
Posted: Sun Oct 30, 2005 7:19 am Post subject: |
so surprised ........ so happy
many thanks smoothie, for your advice  |
bob
Posted: Sun Feb 05, 2006 6:26 pm Post subject: |
Well, now i'm searching for clutch dealer....not in France
how can i do ?
where can i find the ford bronco II 86' clutch for my 931 ?
Someone got an idea?
thanks _________________ yesus a ne fo mvoé djam |
bob
Posted: Thu Mar 02, 2006 2:11 am Post subject: |
anyone for an idea? please help me ...
many thanks  _________________ yesus a ne fo mvoé djam |
dpw928
Posted: Thu Mar 02, 2006 1:05 pm Post subject: |
Smoothie,
In 1991 Porsche changed the pedal adjustment specs on the 928 from .5mm freeplay to 1 complete rotation to preload. Since the 931 and 928 use common clutch release components, I wonder if this change should apply here. Was Porsche still publishing changes to the 924/931 workshop manual in 91?
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Fri Mar 03, 2006 6:18 am Post subject: |
| dpw928 wrote: | | In 1991 Porsche changed the pedal adjustment specs on the 928 from .5mm freeplay to 1 complete rotation to preload. Since the 931 and 928 use common clutch release components, I wonder if this change should apply here. Was Porsche still publishing changes to the 924/931 workshop manual in 91? | I bought my manuals in about 1994 and they're only updated to 1980. I don't know what's been added since then. It's possible that the same recommendation was made for the 931..
Any idea why it was changed for the 928? _________________ "..it's made in Germany. You know the Germans always make good stuff."
dpw928
Posted: Fri Mar 03, 2006 11:11 am Post subject: |
Smoothie,
Not sure why it was changed but readjusting the pedal on my 78 took away all the gear grinding. It's possibly they changed to composition of the blue hose which allowed more expansion.
78 928 5 sp Silver
