Neil924
Posted: Sat Dec 17, 2005 10:24 am Post subject: Rough/ low rpm's at idle. At speed = perfect. |
A 1988 924S, has been running fine but recently at idle the rpms drop, then come back up. It sounds like it isn't getting enough fuel, and is about to die, but it never does. It just has a really rough idle, however under acceleration and cruising it acts perfectly fine. Any ideas? I was thinking maybe a fuel sending problem (i.e. fuel pump).
Any ideas?
P.S. It's not my car. Could it be the injectors or timing or air fuel mixture?
Thanks.
Neil |
Posted: Sat Dec 17, 2005 2:33 pm Post subject: |
| The problem that you describe is a classic symptom of bad engine mounts. |
edh
Posted: Sun Dec 18, 2005 1:20 am Post subject: |
Could possibly be lots of things apart from mounts
Does it vary between hot & cold running?
If you hold it on the throttle at 1k rpm do you get any vibration? _________________ current - '90 944S2, '00 986S,
ex - '90 944 turbo '86 924S, '88 924S |
Neil924
Posted: Sun Dec 18, 2005 2:42 am Post subject: |
| Thanks a bunch. |
Techno Duck
Joined: 12 Nov 2002 Posts: 212 Location: Long Island, New York
Posted: Sun Dec 18, 2005 3:51 am Post subject: |
Neil, do the RPM's fluctuate or do they stay constant? If they stay at a constant the normal idle RPM (about 900) then its probably your engine mounts. If it idles very low, it could be a idle stabilizer valve or your TPS. _________________ 1987 Zermatt Silver Porsche 924S <-- Sold in Nov. '04
1987 Guards Red Porsche 944 <-- Sold in Jan. '08
1988 Guards Red Porsche 951 <-- Das Boost |
Llamaguy
Posted: Sat Jan 14, 2006 2:50 pm Post subject: |
check the fuel pressure regulator and the dampener, sounds like what was happening to mine. _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
Slam
Posted: Fri Jan 27, 2006 5:21 pm Post subject: |
Does engine temperature affect it? Will it idle properly if the throttle switch is adjusted so it doesn't send an on-idle signal? _________________ '88 944 Auto - may or may not resurrect |
