timstar92404
Posted: Sat Dec 03, 2005 9:37 pm Post subject: 924 turbo head gasket set |
Is it the same as a 924 headgasket set? I'm asking because most places have the cheap quality set for the 924 and the better Reinz (oem) quality set for the turbo.
head gasket should be the exact same right? what about all the other gaskets, like the exhaust and intake manifold/ not sure what the various other gaskets are for. I think it would miss the fuel injector seals.
but is the headgasket useable on the 924 and also most of the other gaskets/ seals?
here is a pic
http://www.paragon-products.com/product_p/931.100.901.00.htm
thanks. _________________ 78 924 sold.
85.5 944 |
xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
chris24
Posted: Sat Dec 03, 2005 11:38 pm Post subject: |
I was under the impression that it was thinner and had been used by some guys on this board to get slightly higher compression in their 924NA? So shouldn't it still fit ok? _________________ 1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles) |
