bkantelis
Posted: Thu Nov 17, 2005 6:09 am Post subject: Cold / Warm Idle Backwards |
All,
Hope to tap the experience here. 1979 924NA with new AAV, WUR, injectors, injector seals and fuel pumps. Starts great when cold and starts with the "cold start modification" just fine when warm. The issue is idle seems reversed, it idles low when cold then high when warm. Right now, cold idle is about 700rpm and warm idle 1500, if i turn the idle down when warm then it will not start. Suggestions? _________________ 1979 NA 924
Georgia, USA |
