steering universal joint
juno
PostPosted: Thu Oct 13, 2005 3:18 am    Post subject: steering universal joint Reply with quote
a few months ago I had to have the universal joint repalced for the MOT with a factory reconditioned part. it has been fine up until now, but it has gone worse than the original one.
Is there something else that could be making it fail, or is it just likely to be a faulty part?
1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust.
PostPosted: Thu Oct 13, 2005 3:35 am    Post subject: Reply with quote
How's it failing? -Just getting hard to turn? -Or is it completely shot and developed a lot of free-play?
Mine got hard to turn a couple times - all that was needed was to get a few drops of oil on the u-joints and they loosened right up. It's never been replaced.
Of course yours would be in a completely different environment there among the hot exhaust parts...
juno
PostPosted: Thu Oct 13, 2005 8:52 pm    Post subject: Reply with quote
it still turns freely, but there is a very loud clunk when driving in a straight line above 20 or so. On a slightly bumpy road, it's quite scary how much of a clunk there is.
Mine's the RHD version, btw. Took me a few seconds to figure out how mine would be hotter late night last night
PostPosted: Fri Oct 14, 2005 12:27 am    Post subject: Reply with quote
Are you sure the clunk's coming from the steering u-joint? If it is, you should be able to reproduce it and/or a noticably unusual amount of steering free-play while stopped. Obviously just turn the wheel back and forth and see what it does. Other sources of clunks are the upper strut mount-bearings and ball joints. My first suspect would be the strut bearings just because of the three, that's all that's needed replacement on my own car. For a quick-easy test, pop the hood and push the car sideways at the front while looking at the top-center of the strut where it's fastened atop the mount-bearing. If you see the top of the strut move in relation to the mount-bearing (you might also hear a clunk), it's time to replace them (the mount-bearing assemblies) - they're superceeded by improved 944 parts and you should find them suprisingly inexpensive (they were pretty cheap here, anyway).
AGD931
PostPosted: Fri Oct 14, 2005 12:30 am    Post subject: Reply with quote
Smoothie,
I also have noise from the steering column somewhere when I drive on unsurfaced roads. The only thing I have found is that if I push the steering wheel upwards from the six o' clock position, is that there is a very slight play / gap.
Is the U-joint you mention the one under the brake servo? Do I spray this with penetrating oil as sometimes when I turn left the steering is slightly heavy and whilst parking I hear a "twang' when I turn full lock left.
Thanks for your help.
Arthur
1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia
juno
PostPosted: Fri Oct 14, 2005 12:45 am    Post subject: Reply with quote
yes, it does appear to be coming from the steering at least. when stationary moving the wheel side to side makes the same noise but quieter.
I can feel play in the joint when I hold it and someone moves the wheel, so in my case it does seem to be the universal joint.
just worrying how a £186 part can break in a couple of months.
PostPosted: Fri Oct 14, 2005 1:38 am    Post subject: Reply with quote
It would seem to be a faulty part then - and hopefully covered by a warantee..
Arthur - I had some up-down steering wheel play like you describe and while I had the wheel and locking mechanism out recently, found a questionable part serving as a bushing between the steering shaft and the upper steering shaft bearing... It looked like a short length of clear hose that was slipped over the shaft, then the lock-mechanism/bearing-holder was installed, squishing the hose piece to conform to the space between the shaft and bearing. As far as I could tell from looking at the parts list, it wasn't a factory installed part. -Plus it was electrically insulating the shaft from the chassis, so I had no ground path there. I took it out of there and cut a short piece of 3/4" copper water pipe (the thin-walled stuff that gets soldered rather than screwed together), put a diagonal cut across it, filed off the burrs and slipped that on to the shaft. It's a near-perfect fit between shaft and bearing and the free-play is virtually gone.
For the U-joint: yes, penetrating oil should do fine. I used engine oil, but Liquid Wrench, WD-40, or whatever should serve just as well. I don't know about the "twang" though - I'd think a tire or some steering part's catching, then releasing some metal part.
AGD931
PostPosted: Fri Oct 14, 2005 3:41 am    Post subject: Reply with quote
Thanks Smoothie, spot on
I also have this "hose" in exactly the same location!!! I had seen it last year but gave it no attention. Your post reminded me that the Ford Capri I also own, has a similar "hose". I then remembered that it also had up-down play until it was replaced. As for the ground issue you mention, I cannot recall anything being grounded there, maybe I forget or US / ROW differ in that location.
I will give the U joint a liberal coating and see what happens. As for the "twang" I am also confused as it only does it when parking the car into a space Maybe the rubber bush on top of the MacPherson is dry/breaking up.
Arthur
1981 931 S2
PostPosted: Fri Oct 14, 2005 4:53 am    Post subject: Reply with quote
Well now either our cars were worked on by the same mechanic or that hose piece was actually put there at the factory.
Anywho, my horn's the item that wasn't working because of a lack of ground. I actually took a completely different approach to fix it - with a loosely wrapped wire from steering shaft to ground down near the firewall, but I'd heard that that ground is supposed to happen there at top, from bearing housing to bearing to steering shaft.
scotchw
PostPosted: Tue Oct 18, 2005 8:54 am    Post subject: Reply with quote
Juno - I've recently been doing some work on my steering, & the 'clunk' reminded me of a noise I had after changing my lower steering shaft... for the wrong one
My parts supplier (Euro Car Parts) supplied a 924S shaft which only cost 40GBP & looked the same - but caused clonking noises on turning & didn't feel "right". Of course, the 924S shaft is 10-15mm longer than the turbo one (I discovered when I stripped it out again!). When they told me it was 180GBP for a turbo shaft I decided to oil-up my old shaft - and it freed up nicely - albeit you really need to pry the little rubber seals open to get oil into the actual bearings of the UJ's in the shaft.
I was trying to cure my heavy/stiff steering that really loaded up as you applied the lock. Lube-ing the shaft UJ's helped, as did changing the strut top mounts (bearing had broken away from rubber). I also lubed the steering rack (under the rubber gaiters). But I noticed when turning the steering over with the front of the car raised that there was a clonk/judder from the strut/spring on one side, like it wasn't turning freely with the top mount bearing & lower spring seat, but 'jumping' in stages. This seems to have improved since I undid the strut top nut & greased the rubber ring that sits on top of the strut top/inner wing. It was like the whole top mount assembly was 'grabbing' & too tight. Perhaps my metal spacer that sits inside the bearing/top mount is slightly worn
I've still got the control arm balljoint to replace & the tie rod end balljoints for good measure. I'm hoping the steering will be clonk free & light after all that
'82MY 924 Turbo Euro RHD
numbbers
PostPosted: Tue Oct 18, 2005 10:34 am    Post subject: Reply with quote
Well, the movement in the steering shaft, and psooibly the clunk is caused by the steering shaft bushing (actually a ball bearing) located in the switch mechanism. The original bearing has about a 1/8 inch clearance gap to the steering shaft. Way too much. The bearing has been superceeded by a 944 part that has a plastic insert, that leaves virtually no movement in the steering wheel. It is not expensive, and well worth the trouble to change.
juno
PostPosted: Tue Nov 15, 2005 11:40 pm    Post subject: Reply with quote
smoothie - is this the item described as 'top steering bearing'?
Seems it's this that's wrong with my car as the new universal joint only made a slight difference. Doesn't seem to be any play in the strut top bearings.
PostPosted: Wed Nov 16, 2005 2:25 am    Post subject: Reply with quote
Yes. Take the steering wheel off, remove the wiper and turnsignal switches, then you should find a black plastic sleeve on the shaft that has to be pryed off - then you'll see the bearing. The piece I replaced is another sleeve that's between the bearing and the shaft, and accessible once the steering lock/bearing housing assembly's removed.
juno
PostPosted: Wed Nov 16, 2005 4:33 am    Post subject: Reply with quote
thanks smoothie, will have to sort that one out now, as I've cured the clonk, but still have a small amount of play as you described above.
turns out my 'clonk' was the oil filter touching the bottom shaft, which must be why it felt as if it was a steering problem. undid the adjustment bolt on the oil filter housing and moved it slightly and the clunk has gone. think the engine mount might need replacing, but steering is much better than it's ever been.
