bearing change
geddes66
PostPosted: Sun Nov 13, 2005 1:33 am    Post subject: bearing change Reply with quote
Is it possible to change out the main and rod bearings without pulling the engine? Just pull down the front crossmember, pull the oilpan and install the new bearings? I know new upper mains can be slipped in above crankshafts. Car runs fine, has great compression, NO smoke and a good camshaft but poor oil pressure at temp. Already running 15-50 synthetic.
The Porsche is now my son's, my car is cooler, slower but cooler.
PostPosted: Sun Nov 13, 2005 3:06 am    Post subject: Reply with quote
Yes. You've got it - once the oil pan's off, they can all be replaced.
PostPosted: Sun Nov 13, 2005 4:37 am    Post subject: Reply with quote
I think the mains would be kind of difficult.
augidog
PostPosted: Sun Nov 13, 2005 8:25 am    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=15971&start=0&postdays=0&postorder=asc&highlight=oil+pan
