andyfranqueira
Posted: Sun Oct 16, 2005 7:39 am Post subject: A/C squeals |
If I switch the A/C on at startup, but if I wait a minute it's normally fine. Loose belt?
Last edited by andyfranqueira on Sun Apr 16, 2006 7:36 am; edited 2 times in total |
andyfranqueira
Posted: Tue Oct 18, 2005 5:35 am Post subject: |
Bump
Posted: Tue Oct 18, 2005 6:43 am Post subject: |
I think you guessed it.
Apparently, the belt squeeks when it's cold, so if run a few minutes and allowed to warm itself up, it doesn't squeek.
Looks like the 924S should have an adjustable rod from the compressor to the block. -Should find 2 nuts next to each other toward the end of that rod. Loosen them from each other, then turn the one that's nearest the compressor toward the compressor to tighten the belt. Once you have it where you want it, tighten the 2 nuts up against each other again to lock in the adjustment. _________________ "..it's made in Germany. You know the Germans always make good stuff."
D Hook
Posted: Tue Oct 18, 2005 9:07 am Post subject: |
| andyfranqueira wrote: | | There might be a beer in it.... |
That's the problem. There should be TWO beers in it! Runs smoother, as long as you're using really good beer.  _________________ '80 924 n/a SOLD |
