sleepy
Posted: Mon Sep 12, 2005 7:55 am Post subject: ENGINE |
I was just wondering if a 924 na engine has ever been put in a 944? or is that not possible?
-sleepy _________________ meteor silver 1981 924 lux. -UK |
Neil924
Posted: Mon Sep 12, 2005 8:10 am Post subject: Re: ENGINE |
| sleepy wrote: | I was just wondering if a 924 na engine has ever been put in a 944? or is that not possible?
-sleepy |
I doubt it. A more likely senerio would be a 944 into a 924 and that is hard enough apparently. |
D Hook
Posted: Mon Sep 12, 2005 10:18 am Post subject: |
At the risk of sounding obvious, why would you want to? The 944 weighs more and the 924 engine makes less HP, IIRC.
Like Neil said, usually it's the other way around. _________________ '80 924 n/a SOLD |
timstar92404
Posted: Mon Sep 12, 2005 5:56 pm Post subject: |
haha no one would ever do that. it would be alot of work to do that so even a 944 with a busted engine would just get another 944 engine put in.
I'm guessing if you put the 924 engine in the heavier 944 old people in their motorized scooters are going to be drag racing you and win.... _________________ 78 924 sold.
85.5 944 |
Posted: Tue Sep 13, 2005 5:22 pm Post subject: |
Hey, Sleepy, get a 944 body kit for you 924, or better still a 944!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
sleepy
Posted: Wed Sep 14, 2005 2:30 pm Post subject: |
| Quote: | | Hey, Sleepy, get a 944 body kit for you 924, or better still a 944! |
Not much point in getting a bodykit for my 924 right now mike, the engine is dead & not going anyware
I was just curious if it had been done. Ok then, has anyone ever put a 924 na in a 924 S ? _________________ meteor silver 1981 924 lux. -UK |
81turbo
Joined: 03 Nov 2002 Posts: 1065 Location: Oakland, CA
Posted: Wed Sep 14, 2005 2:31 pm Post subject: |
That is still basically the same question.
Hey guys you had better post again  |
sleepy
Posted: Wed Sep 14, 2005 3:04 pm Post subject: |
yes, but weight wouldn't be an issue with a 924 s. _________________ meteor silver 1981 924 lux. -UK |
Posted: Wed Sep 14, 2005 3:09 pm Post subject: |
actually the 924S chassis is alot heavier than a 924 chassis. _________________ 3 928s, |
Raceboy
Posted: Wed Sep 14, 2005 3:19 pm Post subject: |
Yes, it has been done! My aquintance had an accident with his '84 924 and got '83 944 without engine and tranny cheap, and did this kind of swap. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Wed Sep 14, 2005 4:57 pm Post subject: |
| sleepy wrote: | Not much point in getting a bodykit for my 924 right now mike, the engine is dead & not going anyware |
Sad to hear that, Sleepy.
What's the problem? Is it dead dead or is there hope for salvation?
You sometimes see complete 2l engines on E-bay. They go for about a ton, but you have to collect it yourself. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
ESC944
Posted: Wed Sep 14, 2005 10:56 pm Post subject: |
Do a 924 Turbo swap... thats a thought... for the 944.
Rebuild your 924 NA better than it was, as described in many places, on the board. Go with VW pistons, etc..
I wouldnt put a Stock NA motor into the 944...or 924S considering you are going from CIS to a DME EFI Car... although if you planned to convert to EFI for the 924 motor... again, seems pointless unless you are talking a 931 motor or a seriously built 924 motor and/or a source of boost. |
-nick
Posted: Thu Sep 15, 2005 4:07 am Post subject: |
For the amount of hassle to swap a 2.0L into a 924S/944, it would be easier to drop in a 951 engine. What's the point? You could drop in a 1.6L VW motor too, it's just as silly of an idea.
nick |
sleepy
Posted: Fri Sep 16, 2005 12:19 pm Post subject: |
| Quote: | What's the problem? Is it dead dead or is there hope for salvation?
I think she's a gonner I don't know Exactly whats wrong but this is what happened....
After about 60 miles taking it easy up the M1, i opened up the engine &
did about 110mph for a few miles. She's done that speed in short bursts
before but not for over a mile. Anyway, when i slowed to 80mph there
was a distinct rattle/clatter from under the hood. When i took my
foot off the pedal completely the batt light came on & died & the
engine lost power. It didn't overheat but the oil smelt burnt. It started with a push-start but wouldnt pick up much speed & cut out as
soon as i eased off the accelerator & the clatter was still there.
Had to tow it 70 miles home
What do you reckon the labour cost would be for en enging swap mike? (or how many hours?) _________________ meteor silver 1981 924 lux. -UK |
Posted: Fri Sep 16, 2005 12:29 pm Post subject: |
I would try to find out what the issue is first. then go from there, sounds like a possible bearing failure _________________ 3 928s, |
