tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Sun Sep 11, 2005 9:23 am Post subject: Headlight |
Are the headlamps a common enough item to get (ie are they used on lots of cars)? I mean the round glass bit.
Looks like mine has taken a hard rock hit some time recently. Only just discovered it as the headlight is still working fine. I should just need to replace the headlamp itself. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Sun Sep 11, 2005 9:27 am Post subject: |
| Yep, even a 7" dual filament headlight from a 20 year old Holden will work.... |
Posted: Sun Sep 11, 2005 9:29 am Post subject: |
That said, many of us have converted to Halogen headlights with replacable bulbs. _________________ White 87 924S "Ghost"
tj924
Posted: Sun Sep 11, 2005 9:32 am Post subject: |
| Paul wrote: | | ...many of us have converted to Halogen headlights with replacable bulbs. |
I thought the bulbs were always replacable. _________________ TJ
Posted: Sun Sep 11, 2005 9:33 am Post subject: |
yep, very common. Your local Auto-whatever should have them. I vaguely remember about $90 a pair with H4 globes. _________________ 1979 924 (Gone to a better place)
The holden one's are sealed beam. _________________ Porsche 924 1984 (UK import) NA
tj924
Posted: Sun Sep 11, 2005 9:46 am Post subject: |
| Ozzie wrote: | | The holden one's are sealed beam. |
And I gather "sealed beam" = non-replaceable bulbs?
| Peter_in_AU wrote: | | ...Your local Auto-whatever should have them. I vaguely remember about $90 a pair with H4 globes. |
My headlamps have "H4" written on the front, so that'd be the ones. By "globes", do you mean the glass headlamp bit or the bulbs? The bulbs in mine are fine, I just need a headlamp. _________________ TJ
Gram
Joined: 08 Feb 2005 Posts: 357 Location: Northland, New Zealand
Posted: Sun Sep 11, 2005 9:56 am Post subject: |
That's what sealed-beam are..the filaments are fused onto the reflector..non-replaceable bulbs. _________________ '82 924 NA Euro (hers)
'98 Audi A4 TDI (ours) |
Gram
Posted: Sun Sep 11, 2005 9:57 am Post subject: |
globe=bulb. You just need a lens.. _________________ '82 924 NA Euro (hers)
Posted: Sun Sep 11, 2005 10:01 am Post subject: |
| Agreed, but as I said the Holden sealed beams will bolt right in. Just don't drive when it's dark! |
Posted: Sun Sep 11, 2005 10:07 am Post subject: |
I bought H4 bulbs for $30pr-.
Headlights for $90 a pr should be complete lens as well. _________________ Porsche 924 1984 (UK import) NA
tj924
Posted: Sun Sep 11, 2005 10:08 am Post subject: |
| Paul wrote: | | Just don't drive when it's dark! |
As usual you've come up with the perfect solution Paul! _________________ TJ
Posted: Sun Sep 11, 2005 10:26 am Post subject: |
| In the US we had to put up with sealed beams for years. My 77 that I bought new had them. |
Posted: Sun Sep 11, 2005 11:36 am Post subject: |
| tj924 wrote: |
My headlamps have "H4" written on the front, so that'd be the ones. By "globes", do you mean the glass headlamp bit or the bulbs? The bulbs in mine are fine, I just need a headlamp. |
By globes I mean bulbs. If you just need a shell then it's just beer money. _________________ 1979 924 (Gone to a better place)
leadfoot
Posted: Sun Sep 11, 2005 11:42 am Post subject: |
I have the non-sealed globes, is there any merit in changing to the 4000K globes?? I believe the stocks are 3200K and the extra colour temperature might help a little. I'm not sure if the blue light globes would do anything but look pretty.
I know a few people have upgraded their lights to higher wattage globes, are these 80/120W or something... I know there are limits on the electrics, are these just amperage concerns??
100W / 12V = 8.3 Amps.... stock
120W /12V = 10 Amps... upgrade probably on the limit of burning out stock wiring....
I think if I can get the facts together I'll do a section for the new board. So arm me up with your thoughts and I'll get something together for all.
It's also nice with the non sealed to be able to get in there and clean the lens from behind...
Leafoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
