J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Mon Sep 05, 2005 8:16 pm Post subject: those damn shifter bushings |
I got some in the mail today and went to put them in tonight. easy enough job i thought. the old ones were well beyond gone, they were toast... but is there a knack to doing this? I cant get the last one in (top right one) and i think i've done something. the whole assembly feels loose like something down the other end has popped out... am i right?
- frustrated! _________________ '86 944 |
Posted: Tue Sep 06, 2005 6:46 am Post subject: |
I replaced the front ones and the ones in back. Maybe the knuckle came
off in the back.. Im guessen its a 5 spd. I replaced all of mine a yr ago
what a diff that made..Howed you do it? Drop the tranny?. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Tue Sep 06, 2005 11:28 am Post subject: |
if you are speaking of the ball cup on the rear of the torque tube, then the easiest way to get it back on is believe it or not a REALLY big hose clamp, it needs to be iirc 5" to go around and catch, then just tighten down, but make sure that you use some lithium grease on the ball and cup, and make sure it is in the right position when you start to clamp.
good luck with it as those ball cups are a PITA without that trick  _________________ 3 928s, |
J1NX3D
Posted: Tue Sep 06, 2005 12:47 pm Post subject: |
| Joes924Racer wrote: | I replaced the front ones and the ones in back. Maybe the knuckle came
what a diff that made..Howed you do it? Drop the tranny?. |
i was just doung the front ones, i have a snailshell. i havent dropped the tranny _________________ '86 944 |
J1NX3D
Posted: Tue Sep 06, 2005 12:49 pm Post subject: |
| Lizard wrote: | if you are speaking of the ball cup on the rear of the torque tube, then the easiest way to get it back on is believe it or not a REALLY big hose clamp, it needs to be iirc 5" to go around and catch, then just tighten down, but make sure that you use some lithium grease on the ball and cup, and make sure it is in the right position when you start to clamp.
good luck with it as those ball cups are a PITA without that trick  |
is this with the tranny still in place? _________________ '86 944 |
J1NX3D
Posted: Tue Sep 06, 2005 5:49 pm Post subject: |
thanx lizard and paul, i'll try and pick up a hose clamp this week _________________ '86 944 |
