Questions
BillA
PostPosted: Sat Sep 03, 2005 3:54 am    Post subject: Questions Reply with quote
Does anyone happen to know if there are different size (length) connecting rods for the NA engine, or would I have to look for aftermarket. Also, how about the crankshaft, which would create a longer stroke. Thanks!
BillA
Of all the things I've lost, I miss my mind the most!
Mark Twain
PostPosted: Sat Sep 03, 2005 10:53 am    Post subject: Reply with quote
there is only 1 crank shared between the 924/931/937
and the rods I believe to be the same, but not 100% on that.
as for lengthening the stroke, you can buy a stroker kit from Paeco iirc, or you can do a board search as there is some interesting ideas, but you will need to read the posts and gather your own info as well.
3 928s,
PostPosted: Sat Sep 03, 2005 1:23 pm    Post subject: Reply with quote
yea bill the rods are all the same there is interesting posts on fitting
rods from say a vw or I think from some audi motorwith different stroke..Best thing
is to do a search on rods.
BillA
PostPosted: Sat Sep 03, 2005 9:19 pm    Post subject: Questions Reply with quote
Thanks!
