Modoc
Joined: 22 Dec 2004 Posts: 155 Location: Rexburg, Id / Fremont, Ca
Posted: Sun Sep 04, 2005 12:09 pm Post subject: antenna |
err, any tips on replacing the antenna, im not exactly sure what is in the way but theres something in the way of me getting directly into the wheel well and getting directly to the antenna should i be worried about temporaly removing this part?
924s btw...
1988.. _________________ Proud owner of
'88 924s - Sold
'01 ML430
'97 Honda Civic |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Sun Sep 04, 2005 2:34 pm Post subject: Re: antenna |
| Modoc wrote: | err, any tips on replacing the antenna, im not exactly sure what is in the way but theres something in the way of me getting directly into the wheel well and getting directly to the antenna should i be worried about temporaly removing this part?
924s btw...
1988.. | try this, maybe its a better alternative?
http://www.924board.org/viewtopic.php?t=15069 _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Llamaguy
Posted: Sun Sep 04, 2005 3:41 pm Post subject: |
that would probably be the cabin air filter, You can take it out and leave it if you want. I broke mine on accident and didn't feel like fixing it. _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
Posted: Mon Sep 05, 2005 1:36 am Post subject: |
It's the charcoal canister (used to recycle gas fumes from the tank).
It's held in by two bolts, just remove it. Be careful if you elect to remove the hoses, they are probably very brittle. |
