kewpie79
Joined: 20 Mar 2004 Posts: 109 Location: Los Lunas, New Mexico
Posted: Sat Sep 03, 2005 4:45 am Post subject: engine woes |
Finally have spark. Will crank, backfire and turnover, but will not start completely. Took it to a mechanic (towed). Stated the engine is probably dead since two of the cylinders are extremely low on compression. Also said he added oil and it held its pressure for awhile, but then went down again. I'm clueless at this point. He said he is going to try to pull it and see if it will start in second gear and hopefully the rings will re-seat themselves. If this doesn't work, do I need an entirely new engine, or can it be rebuilt? Or are there any other tricks to consider? _________________ 1980 Porsche 924
1984 Pontiac Grand Prix
2003 Kia Sorento |
Jazzerpet
Posted: Sat Sep 03, 2005 5:34 am Post subject: |
How long has the car been sitting?
The reason I ask is I have found the top rings busted on two different engines that have not been started in 3 years. On the up side the cylinder walls were not scored and the rings for an NA are easy to find. The fuel distributors on both were gummed up and prevented starting as well. _________________ 1980 931
1985 ½ 944
Member of the “Omaha Crew” |
kewpie79
Posted: Sat Sep 03, 2005 5:36 am Post subject: |
it had been sitting for a couple of years. _________________ 1980 Porsche 924
2003 Kia Sorento |
Posted: Sat Sep 03, 2005 7:27 am Post subject: |
Low compression can also be valve timing not set correctly.
I'd check and double check valve and ign timing _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Sep 03, 2005 10:10 am Post subject: |
ign timing would not affect compression,
however if the timing belt was off a tooth or two that would affect compression, but would do it to ALL cyl,
I would ask the mech what all the cyl compression #'s were first, and then I would do a leakdown test to see if it is a burnt valve, blown headgasket, or sticky rings. _________________ 3 928s, |
kewpie79
Posted: Sun Sep 04, 2005 8:20 am Post subject: |
thanks for the input and help. _________________ 1980 Porsche 924
2003 Kia Sorento |
Posted: Sun Sep 04, 2005 9:17 am Post subject: |
| Quote: | | ign timing would not affect compression. |
no- But it will stop it running.
| Quote: | | affect compression, but would do it to ALL cyl |
Depends on valve clearances.
Just covering all bases. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Sep 04, 2005 9:31 am Post subject: |
if its all timed right and still does it & fails a leakdown test it
should just need a rering job done on all pistons...easy thing to do
to the 924. You dont even need to take the engine out ... just the pistons
Im wonderen what thatll cost to have done in a N.M. shop verses doing it yourself. parts should only be about in the 250.00 to 300.00 range
youll need a head gasket pan gasket and maybe a intake gasket
the rings new oil and maybe some sealent. & the tools of course if you wanted to do it yourself. Youmight encounter some broken bolts along the way in the exhaust removal though I dont think you would
have to remove the manifold youd just need to undo the downpipe
from it. Youl also need someone strong enough to lift the head off
with the manifold in place. Myself Ive found it to much to lift off the head with the intake and exhaust in place so I remove the intake. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sun Sep 04, 2005 9:32 am Post subject: |
Incorrect timing would lead to a failed leakdown test though
or compression test. make sure its timed right. _________________ 1979 porsche 924 Na
CBass
Posted: Sun Sep 04, 2005 11:37 am Post subject: |
The oil is added to verify whether the rings are bad or not. If the numbers go up for a while when oil is added during a compression test, it means the rings are toast.
The engine can be rebuilt by a chimpanzee, barring machine work. _________________ '81 931 in various states of assembly |
