Exhaust manifold gasket fix 78 NA, should I try it?
augidog
PostPosted: Sun Aug 28, 2005 11:28 am    Post subject: Exhaust manifold gasket fix 78 NA, should I try it? Reply with quote
Should I go for it or leave it for a muffler guy? I'm on vacation this week.
PostPosted: Sun Aug 28, 2005 11:36 am    Post subject: Reply with quote
depends on how much money you have.
Those nuts can be a real pain to get off and most guys will just lean on them until the stud snaps then the bill just went up by a couple of hundred.
If you take your time and use plenty of penetrating oil it's not that hard.
CBass
PostPosted: Sun Aug 28, 2005 5:39 pm    Post subject: Reply with quote
Patience is the key here, that and a couple cans of liquid wrench. Be sure to give the nuts a good brushing with a wire brush before soaking, and between soaks.
PostPosted: Mon Aug 29, 2005 9:21 am    Post subject: Reply with quote
I would say go for it, just make sure that you buy all new replacement nuts (the copper locking style) and all new exhaust studs, as well as having a M8x1.25 tap to clean the holes out, and possibly a helicoil handy, as well as remembering to use neversieze/antisieze on the part of the exhaust stud which is not covered, and possibly on the part that goes into the head (however I found mine tended to back out if I used it here)
3 928s,
augidog
PostPosted: Mon Aug 29, 2005 11:10 am    Post subject: Reply with quote
I'm going to Napa tomorrow for the bolts and manifold gasket.
I've read I can just ask for the VW replacement manifold bolts .
Is there a year that will work in-case this guy panics?
PostPosted: Mon Aug 29, 2005 11:40 am    Post subject: Reply with quote
just say 1.8L 1983 VW rabbit, the studs and nuts are exactly the same, and as I said replace them all, or at least I would
3 928s,
