questions about boost gauge and , timing, and oil temp gauge
Miker
PostPosted: Sat Sep 17, 2005 4:03 am    Post subject: questions about boost gauge and , timing, and oil temp gauge Reply with quote
hi all,
I have a few questions about boost gauge and controllers, timing set uo and oil and water temp guages.
1. I have a vdo boost gauge and i have no idea where, how to koo it up?
2. Can you tell me what boost contoller is good for not to muh money and how, where to hook it up?
3.Where in the world can i hook up a oil temp gauge? i have a vdo gauge from vw
4.will a vw vdo temp gauge work with the factory sending unit
5. how to you set timing at the crank, cam and distrubuter. I have had the motor out and apart but have never in my life set timing - detailed instructions would be great - i understand TDC etc but not sure how exactly.
thanks all
Mike
1980 924 Turbo (in pieces right now, but getting there) almost there
1987 911 Carrera 3.2
2000 Getta VR6
-nick
PostPosted: Sat Sep 17, 2005 4:21 am    Post subject: Reply with quote
Hi Miker,
All your questions should be answerable with the "search" button. Some of the topics have been up several times. Take a peek first.
nick
Miker
PostPosted: Wed Sep 21, 2005 9:19 am    Post subject: i have searched and cannot find the info that i need??? Reply with quote
ok i have searched for two days, searched searched and searched more. Maybe im asking the wrong questions?
My dilema, I removed the engine and while I had it out replaced the timing belt and other stuff (like everything) But I am sure that whole replaceing the belt the cam turned some.... The manual says to set up the cam gear to the mark and go ahead. This cannot be all. I must have to make sur ethe bootom end is the same as the top end. HELP Im out of my league I have no idea how to set timing in this car, oops or any car i guess!! I have a friend you has some experience but i want to be 100% sure how to set it all up. So if anyone can help that would be excellent. You could refer me to an article or other site or just explain in great detail what to do!!! Thanks
2000 Getta VR6
John Brown
PostPosted: Wed Sep 21, 2005 1:39 pm    Post subject: Reply with quote
There is a small notch in the crank pulley. Line the notch up with the pointer.
Then double check the mark on the flywheel through the timing window - very hard to see.
Then set the cam timing 'dot' on the backside of the cam pulley to the pointer.
Adjust the timing belt tension and recheck marks.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
Miker
PostPosted: Thu Sep 22, 2005 3:25 am    Post subject: Reply with quote
thats it, that will match the bottom end to the top end. I was worried that I would have the top and bottom at opposites. So, im good then thanks!!!
Mike
2000 Getta VR6
