Yet another AAV question
tj924
PostPosted: Sun Aug 28, 2005 9:13 am    Post subject: Yet another AAV question Reply with quote
I have had a cold start/initial rough running problem for a couple of months now & decided to pull & check my AAV yesterday. When "cold" (around 15C I'd guess) it was probably 90+% closed. I put it in the freezer for 6 hours & the hole was still 70+% closed (but it definitely does open up more)
I have seen other posts where people talk about cleaning & adjusting the AAV. I gather the adjustment is the little nut on the front of it, but how can I clean it?
I'm thinking of heating it up (hairdryer) &, assuming it closes all the way, adjusting it until it is just closed to see if I can get the hole any bigger when cold. Does that sound reasonable?
TJ
PostPosted: Sun Aug 28, 2005 10:48 am    Post subject: Reply with quote
My AAV is different, but by my understanding of the NA's AAV that nut isn't a direct adjustment of the opening - instead it locks the adjustment in place. To adjust, with the AAV fresh out of the freezer you'd loosen the nut and reach in with a screwdriver and push the valve open to where you want it, then tighten the nut again. That's how it would go in a perfect world anyway. Count on having to do it more than once. -And if you open it too far and need to close it some, I don't know...maybe drill a little detent in the valve plate so it can be pulled back the other way with a pick.
To clean, just spray some carb cleaner in there, shake it around, let it drain.
PostPosted: Sun Aug 28, 2005 10:53 am    Post subject: Reply with quote
I dont think that cold starting would be an issue for you down under
3 928s,
tj924
PostPosted: Sun Aug 28, 2005 11:28 am    Post subject: Reply with quote
I thought it was the cold engine that had to be overcome more so than the cold air temp, so the AAV function would still be important. From my searching on the post I think it more likely to be a WUR problem (difficult cold & hot start + rough running until it is warm + slight hesitation while cruising).
Anyway, I heated the AAV with the heat gun (actually my wife's hairdryer, but "heat gun" sounds more manly & "toolish") & it did close completely.
Smoothie wrote:
...that nut isn't a direct adjustment of the opening - instead it locks the adjustment in place. To adjust, with the AAV fresh out of the freezer you'd loosen the nut and reach in with a screwdriver and push the valve open to where you want it, then tighten the nut again...
Thanks Smoothie, I'll try that a little at a time. I thought I might try it in the fridge rather than freezer as that will much more closely approximate our lowest temperatures.
TJ
PostPosted: Tue Aug 30, 2005 5:22 pm    Post subject: Reply with quote
Update on AAV adjustment.
I've tried a couple of times to adjust a spare AAV I've got, like it says in the Alfa GTV website, but it never seems to work.
I loosen off the nut; no problem, move the disc one way or the other ; no sweat, then tighten the nut with the disc in the 'right' place and it always springs back to where it was to start with.
I've tried both AAVs on the car and there is no difference in the way the engine behaves, so I've given up trying.
At around 15°C, you should be able to see about a 2 - 3 mm square hole in the disc, at over 40 - 50 °C (engine running temp.) the hole closes completely. If you cool it down to about 0°C (freezing, so this shouldn't be a problem in your case, tj!), you see a roughtly-triangular opening about 1/3 the area of the disc.
tj924
PostPosted: Tue Aug 30, 2005 5:56 pm    Post subject: Reply with quote
Mike924 wrote:
I've tried a couple of times to adjust a spare AAV...but it never seems to work.
Yep, thats exactly what I found.
Exactly what I found. Sounds like my AAV is within spec & I probably have a WUR problem. I'm waiting on my replacement Fuel Accumulator & a vacuum test guage to arrive so I'll look into the WUR situation if it still isn't resolved with thos changes.
TJ
timstar92404
PostPosted: Tue Aug 30, 2005 7:17 pm    Post subject: Reply with quote
I have the same cold and hot start problem. idles too lough and less power when starting from cold engine.
my aav also seems to function. opens up about 70 percent or so after one hour in the freezer.
78 924 sold.
85.5 944
PostPosted: Wed Aug 31, 2005 2:10 am    Post subject: Reply with quote
Two more thoughts on adjusting the NA AAV - If it can be disassembled by removing the black plastic end where the electrical connector is, I think you should find the bi-metal strip attached. Once it's out, it could be bent one way or the other to adjust the valves' opening.
-or-
If the black plastic end can be turned (and again, the bi-metal strip is attached to it), then some adjustment should be possible by simply turning it.
PostPosted: Wed Aug 31, 2005 4:58 pm    Post subject: Reply with quote
Good thinking, Smoothie.
I don't think the plastic connector can be turned, because it's retangular in cross-section, but it may be possible, with the right amount of judicious force, to remove it and get at the bi-metallic strip from that end.
I don't think it's worth it in my case. I've come to the same conclusion as tj924, that my AAVs (one on the car and the spare) are both working as intended.
However, I'd still like a few more revs in the colder weather and I think the easiest way to get this is to enlarge the hole in the disc, say with a drill if I can get in there. Now I've got the spare AAV, if I trash it I can still use the car.
Tim and TJ: it sounds to me like you've both got WUR problems.
