air conditioning and removable sunroof
ATL_racer
PostPosted: Tue Aug 09, 2005 7:43 am    Post subject: air conditioning and removable sunroof Reply with quote
The fan in my car blows air, its just not cold. I bought and installed a retrofit kit to change the system to r134a. but still the air is not as cold as it should be, or cold at all for that matter. Any suggestions on what could be wrong/broken. Or at least some ways to do diagnostics on the system.
On my car i have a moon roof, but when i drive with the car open i get a really loud buffeting wind sound that gets really loud on the highway. And suggestion on air deflectors?
late 1979 porche 924, red 2.0l NA 5speed snailshell
Plans: Restore exterior, revitalize interior, install killer sound system, run engine in stock form and have fun.(+ a short throw shifter if i can find one)
PostPosted: Tue Aug 09, 2005 9:30 am    Post subject: Reply with quote
It could be a lot of things. Clogged expansion valve, bad compressor, moisture in the system, dirty evaporator, etc.
Or maybe the fact that 924s before 1987 have really marginal A/C systems.
I would take the system to a pro for a $35 checkup.
In regards to the wind noise, do you have your stock deflector in place?
Also opening the windows about an inch will lessen the noise.
ATL_racer
PostPosted: Tue Aug 09, 2005 10:54 am    Post subject: Reply with quote
i dont have a stock wind deflector or atleast i dont think i do, any as of right now my windows dont work (bought new switches today). If someone can post a pic i could tell for sure.
and ill call around to see where i can take my car the get the ac checked.
thanks
PostPosted: Tue Aug 09, 2005 11:04 am    Post subject: Reply with quote
The stock deflector is about 3 or 4 inches high and slides into the front of the sunroof as you put it back on. You can't miss it!
PostPosted: Tue Aug 09, 2005 1:07 pm    Post subject: Reply with quote
Paul is spot on. We were driving with it up and the windows were up and no problem.
I folded it down, my ears popped and a real loud hum started. I put it back up real quick.
If yours is missing this will be the problem.
A/C- best to get it checked by a tech.
WhoDak
PostPosted: Tue Aug 09, 2005 1:24 pm    Post subject: Reply with quote
If your wind deflector(long black hinged plastic) and you're cruising down the expressway you'd better watch your sunroof panel doesn't lift off and fly away. The wind deflector is the only part on the front of the sunroof that it secures too...I hope you weren't on the expressway long if you don't have one at all
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
ATL_racer
PostPosted: Wed Aug 10, 2005 5:59 am    Post subject: Reply with quote
My sunroof stays put just fine, but i definatley do not have a piece of hinged plastic that stores in the front of the sunroof(though i can imagine how it works) Ill call up the junkyard and see if i can find a used one, but i also need to get a new sunroof gasket, the one on my car is not stock and sticks up about 1/3 inch above the car all around the seal, plus the latch above the passenger seat is broken, is it easy to fix?
Nick_UK
PostPosted: Sat Aug 20, 2005 10:42 pm    Post subject: Reply with quote
do all 924's come with a/c?
PostPosted: Sun Aug 21, 2005 4:07 am    Post subject: Reply with quote
NO not all 924 came with ac
3 928s,
Nick_UK
PostPosted: Sun Aug 21, 2005 4:40 am    Post subject: Reply with quote
Im from the UK. Is it common for them to have it over here?
Is it an optional extra or standard on lux cars??
thanks in advance!
Gram
PostPosted: Sun Aug 21, 2005 5:18 am    Post subject: Reply with quote
Option..I've got a lux with no AC.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
kike924
PostPosted: Sun Aug 21, 2005 9:08 am    Post subject: Reply with quote
My car has both A/C and removable roof, I hardly ever open the roof but I use the A/C a lot specially in summer
Euro 924 1980 N/A
Daily driver + week end racer
J1NX3D
PostPosted: Sun Aug 21, 2005 10:04 am    Post subject: Reply with quote
i have neither i cooked last summer but i had fun
'86 944
Gram
PostPosted: Sun Aug 21, 2005 10:41 am    Post subject: Reply with quote
J1NX3D..thought all 924's had a sunroof..?
J1NX3D
PostPosted: Sun Aug 21, 2005 12:04 pm    Post subject: Reply with quote
hi Gram,
You can get 924's and 944's with a sunroof delete option. its not incredibly rare, but its not common either
[edit] with the trouble i had with rust in my old 924's sunroof, i was so glad to find one without a sunroof, but i know i'll miss it!
'86 944
