Updated Pictures!!! My 924 Turbo...
flosho
PostPosted: Fri Aug 19, 2005 1:53 pm    Post subject: Updated Pictures!!! My 924 Turbo... Reply with quote
Not one of its better days..
This is my car how it sits as of monday.. :tdown:
You can see in this pic at least 6 of the valves are bent, its hard to tell on some, but they are supposed to be "sealed" and you can see daylight around cylinder 1 and 2's valves..
[This Space For Rent]
flosho
PostPosted: Fri Aug 19, 2005 2:02 pm    Post subject: Reply with quote
Oh yeah.. any suggestions on..
Performance head gasket?
Performance Head studs?
Depending on how much they want for stock valves, whats the resource for oversized valves? I have an extra cylinder head/cam(regrind...)
timstar92404
PostPosted: Fri Aug 19, 2005 3:14 pm    Post subject: Reply with quote
Looks like a huge amount of work.....
78 924 sold.
85.5 944
-nick
PostPosted: Sat Aug 20, 2005 7:51 am    Post subject: Reply with quote
Bummer...
You can pick up raceware headstuds (Pelican parts sells them among others). I think they're around $180 for the set.
The stock headgasket should be find unless you start hitting 1+ bar boosts (even then it depends). That is, as long as everything is in good tune.
PS- get that green coolant out of there!
nick
PostPosted: Sat Aug 20, 2005 8:06 am    Post subject: Reply with quote
JHey flosho yer work bench looks like mine does most of the time.
Suppose once I bump my cp by a point and a 1/4 plus use the late style pistins Ill have a so high cp Ill have to look into the receware studs. As
cp will be around 9 & a half to one. thats not bad for an early na with pnp
& reground cam plus header an a full flow catback 44 exhaust. cam gear
webber single throat tb an msd 6a hopefully with deeves rings an a lightenend flywheel.
Good luck flosho.
numbbers
PostPosted: Sun Aug 21, 2005 10:16 am    Post subject: Reply with quote
Flosho, I have a head that has a small grove where the head gasket blew, but all of the valves are good.
