collin41899
Joined: 30 Oct 2004 Posts: 72 Location: new port richey florida
Posted: Tue Aug 16, 2005 8:28 am Post subject: intake |
Has anyone modified their intake and throttle body and all that on a 77 or a yeer that has same engine?? Are their any options??
THanks
Collin _________________ Collin
yellow 1977 924 turbo!?! |
Posted: Tue Aug 16, 2005 8:45 am Post subject: |
what do you mean modified the intake? do you mean shortened the runners, or switched to ITB, or what need more info as to what exactly you wish to do, other intakes have been done, however all custom jobs, most probably were NOT flow bench tested, nor made any real improvement without other modifications. _________________ 3 928s, |
collin41899
Posted: Tue Aug 16, 2005 9:21 am Post subject: |
well i have an aftermarket turbo..and i wanted a little better airflow..and it dosent seem like u can jus bolt on an aftermarket cold air intake..so does anyone know anything that can be done? _________________ Collin
Posted: Tue Aug 16, 2005 12:58 pm Post subject: |
no bolt on except for the Weber redline throttlebody, but it isnt very easy to find (though I have 1 and will be listing it for sale once I am finished at the current job,
other than that you arent going to be able to buy anything, you will have to custom fab, and you wont gain much if any! _________________ 3 928s, |
JamesWilson
Joined: 10 Jun 2005 Posts: 132 Location: San Diego, CA
Posted: Wed Aug 17, 2005 3:51 pm Post subject: |
There is a RedLine Weber throttle body on eBay right now. If anyone has the exact part number, I am a RedLine Weber distributor and can find out if such an animal exists in the old warehouses.
-JamesW _________________ '82 924 Turbo (not stock) - soon returning home?
www.AffordableRacingData.com |
CBass
Posted: Wed Aug 17, 2005 7:41 pm Post subject: |
The MK2 VW Jetta/Golf throttle body is a bolt on upgrade, as is the Audi 5000 throttle body. Both are larger than stock by a considerable margin, and can be found at junkyards all across the world.
The MK2 VW t/b would be my recommendation, for price and availability. When installing one, you'd have to port the intake manifold opening to be the same size as the larger throttle body, or it'll flow worse than with the original t/b.
A Weber Redline t/b will flow better than either, and have better throttle response. It would be especially beneficial for a turbocharged 924, which is why on the '81/'82 931, they adopted a large single blade throttle body like the Weber Redline. _________________ '81 931 in various states of assembly |
Posted: Thu Aug 18, 2005 2:26 am Post subject: |
you also must consider how the turbo hooks upto the intake as well.
as per the part #, I just looked and cannot find 1 on it, and it also has a base/adapter plate that doesnt have a part # either, _________________ 3 928s, |
Chrenan
Posted: Thu Aug 18, 2005 3:52 am Post subject: |
I just did the Audi 5000 throttle body upgrade, very easy. _________________ 1987 951 - M193 Version for Japan |
collin41899
Posted: Fri Aug 19, 2005 10:20 am Post subject: |
do all the original lines and hoses and what not fit if u put on a weber redline throttle body? Im geussing you need to rplace the throttle cable.? _________________ Collin
JamesWilson
Posted: Fri Aug 19, 2005 10:22 am Post subject: |
RedLine Weber part number TB8380, they are checking availability in their warehouses as we speak. I should know by Friday.
-JW _________________ '82 924 Turbo (not stock) - soon returning home?
augidog
Posted: Fri Aug 19, 2005 11:48 am Post subject: |
| CBass wrote: | . When installing one, you'd have to port the intake manifold opening to be the same size as the larger throttle body, or it'll flow worse than with the original t/b.
The Redline has an adapter to fit the regular stock opening, so why using the Audi TB would the manifold have to be Ported?Your not getting more air flow just a quicker throttle.I would think just an adapter if anything and just because it may "whistle" without it. _________________ 1978 924 95 mile daily driver.
JamesWilson
Posted: Sat Aug 20, 2005 3:21 am Post subject: |
Just got off the phone with RedLine Weber, no part available any more, though they have seen interest. With the Weber factory shut down for a few years, when you're out of parts, you're out. Somebody grab that one on eBay then! _________________ '82 924 Turbo (not stock) - soon returning home?
collin41899
Posted: Sat Aug 20, 2005 6:07 am Post subject: |
so does anyone have one for sale????? _________________ Collin
-nick
Posted: Sat Aug 20, 2005 7:22 am Post subject: |
I've got an extra Audi TB (with bigger butterflies). I could send it to you for $30 shipped. I was planning on popping it onto ebay this week, along with a bunch of other bits.
Let me know,
nick
email: rn_durham AT hotmail.com |
Posted: Sat Aug 20, 2005 8:07 am Post subject: |
I do but you will have to wait until the end of sept when I return to the real world for abit. _________________ 3 928s, |
