Driver Seat
AGD931
PostPosted: Mon Aug 01, 2005 4:02 am    Post subject: Driver Seat Reply with quote
Hi to all,
Has anybody had the drivers seat stuck all the way forward (or back) and been unable to slide it in any direction?
This is what happened this afternoon as I moved the seat forward to vacuum the car. A metal rod that connects the releasing catches between themselves also fell out. Have spent most of the evening trying to release the catch that is not attached to the seat sliding lever with no success.
I cannot remove the seat because only the two rear bolts are visible.
Any ideas?
Thanks
Arthur
1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia
PORSCHEV
PostPosted: Mon Aug 01, 2005 8:55 am    Post subject: Reply with quote
You MIGHT be able to remove the 2 rear bolts and tip the seat far enough ahead to hook the linkage back up. Although my 76 has no linkage like you describe.
1978-#53 "D" track racer.
Vince Ponz
PostPosted: Tue Aug 02, 2005 7:45 am    Post subject: Reply with quote
Remove the pass side seat to see how the lever works. You may have to get a screwdriver and hammer to pound out the pieces broken off. Turn seat over and play with the pass seat rails to see if you can figure out how they work and how you have to punch out the broken parts.
I may have a seat rail.
By the way that metal is very strong and I don't know how it would break.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
AGD931
PostPosted: Wed Aug 03, 2005 5:43 pm    Post subject: Reply with quote
Thanks for your help, I found the problem
My car is fitted with the pinstripe seats from a late 944 and therefore have electric height adjustment. The metal rod I described in the first post, links the two catches together, so that when you lift the lever to slide the seat, both catches are actuated.
I refitted the metal rod, closed the ends slightly with a pair of pliers and finished.
Thanks
1981 931 S2
