1987 Porsche 924 Starts but after 5 mins shuts off!
formula05
PostPosted: Sat Nov 20, 2004 9:34 am    Post subject: 1987 Porsche 924 Starts but after 5 mins shuts off! Reply with quote
The Porsche starts up then shuts off after 5 mins. It has new spark plugs, fuel pump, fuel filter, gas filter, air filter, battery , refference sensor and ignition coil. Its an automatic in case that matters(which i doubt). I checked all the grounds , the dme. Its starts up fine but after 5 mins it shuts off then when i try to re-start it, it wont restart unless i wait like 10 mins. If any has any ideas please reply thank you.
(Thanks for those of you who posted last time trying to help me.)
1987 Porsche 924
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 9:36 am    Post subject: Reply with quote
I'd try a DME relay next...
formula05
PostPosted: Sat Nov 20, 2004 9:38 am    Post subject: Reply with quote
I had it tested in another 924 and it works perfect.
thanks
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 9:39 am    Post subject: Reply with quote
Yeah, I just read your last thread again....
What does it do when it shuts off? Say you going down the road and it dies....
formula05
PostPosted: Sat Nov 20, 2004 9:41 am    Post subject: Reply with quote
It just shuts off like if i hit the ignition key in the off position. the lights stay on and everything.
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 9:45 am    Post subject: Reply with quote
So say you are going about 50 mph in 5th gear, does the tach needle immediately drop to zero or does it spool down with the motor?
formula05
PostPosted: Sat Nov 20, 2004 9:47 am    Post subject: Reply with quote
Yeah the motor shuts off quick and the rpm tach just drops straight down to 0.
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 9:51 am    Post subject: Reply with quote
I'd but a voltmeter on the + of the coil and ground the other lead. Then place the meter where you can see it and run the car until it stops. See if the voltage drops.
Have you checked the ignition switch?
How did you check the DME?
formula05
PostPosted: Sat Nov 20, 2004 9:54 am    Post subject: Reply with quote
I havn't checked the ignition swith yet. I checked the Dme by putting it in another 924 and it started fine and ran without a problem. This may sound stupid but i have a vold meter i just dont know how to use it. What setting do i put it in so i can read the voltage.
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 9:55 am    Post subject: Reply with quote
You should have a setting that says "DC Volts"
formula05
PostPosted: Sat Nov 20, 2004 9:57 am    Post subject: Reply with quote
Im going to do that when i get home today. The reason i asked you that is because the one i have has 2 different dc's.
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 10:00 am    Post subject: Reply with quote
Is it an analog (has needle) or is it a digital one? What brand and model is it?
formula05
PostPosted: Sat Nov 20, 2004 10:01 am    Post subject: Reply with quote
I have no idea. I bought it a few months ago. It has a digital screen and has two prongs with needles. One for pos. and neg.
1987 Porsche 924
PostPosted: Sat Nov 20, 2004 10:02 am    Post subject: Reply with quote
The next time it won't start, pull the electrical connector to one of the injectors and see if it will start.
PostPosted: Sat Nov 20, 2004 10:04 am    Post subject: Reply with quote
Time to take the wife out for dinner, I'll check in a few hours and scotches....
