Lousailor Guest
Posted: Tue Dec 11, 2001 6:21 am Post subject: |
Can I replace my stock (stamped steel) A-arms with the solid aluminum versions from a later 944? Thanks
swicks Guest
Posted: Wed Dec 12, 2001 6:20 am Post subject: |
yes, but you don't want to. the pressed steel versions are more reliable and accept bushes etc from a VW Golf/Jetta.
The alloy ones tend to have ball joint problems, but are slightly lighter than the steel.
To make handling crisper, try and get some nylon bushes turned up for all the inner mounts
Cheers
Steve |
924_fan Guest
Posted: Thu Dec 13, 2001 3:39 am Post subject: |
According to the 944 shop manual to install the light alloy control arms (aluminum a-arms), you also need to replace:
the caster eccentric
the stabilizer to control arm linkage
the bearing parts
This list is for changing a 944 over. I don't know if you would also need to get a 944 stabilizer bar.
Skip Denton
'79 924 Sebring
[ This Message was edited by: 924_fan on 2001-12-13 04:40 ] |
