Steering racks
Kenodog
PostPosted: Mon Jul 04, 2005 4:33 am    Post subject: Steering racks Reply with quote
Does anyone know if a manual steering rack from an 84 944 will fit on my 80 931 ?
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Mon Jul 04, 2005 5:39 am    Post subject: Reply with quote
No, it won't.
The steering shaft is a different length.
I haven't checked, but the mounting may be different as well, since the 944 has a cast alloy crossmember and the 924 is pressed and welded steel.
A 944 manual steering rack is much more rare (and expensive) since the manual steering rack was replaced by the power steering rack as standard equipment for the 84 model year.
If you have a 944 manual sttering rack in good condition (and you need a 924 rack), sell it. 944 race guys are always looking for 944 manual racks. Then, you can use part of what you get for it to buy a 924 rack since they are more plentiful (and cheaper).
PostPosted: Mon Jul 04, 2005 6:33 am    Post subject: Reply with quote
I would have given it a definite maybe. The racks look basically the same and use the same tie rod ends. Differences are in the attachment to the crossmember (although the bolt size is the same at M8x60, the 944 uses seperate "clips" and bushings while the 924 rack has welded-on "clips" for the bolts - and as a result it appears the 944 bolts are spaced further apart top-to-bottom of the rack (side-to-side spacing may be the same)(-and the diameters of the racks appear to be the same in the attachment area) -But being the resourceful type, I'd think you'd have no trouble fabricating your own "clips". Other unknowns (to me) and possible hang-ups are the steering shaft U-joint to rack spline size and the gear ratio.
John Brown
PostPosted: Mon Jul 04, 2005 12:23 pm    Post subject: Reply with quote
I do find different part numbers.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
