intake manifold torque settings
PostPosted: Sat Jun 25, 2005 4:38 am    Post subject: intake manifold torque settings Reply with quote
I am still trying to chase down an elusive vacuum leak. I've retorqued the intake manifold, but I was not able to find the proper torque values anywhere in Haynes, Factory Service Manual, or the 924 tech specs documentation. Anyone know what they should be?
Since retorque-ing by feel didn't solve the problem, my next step is to replace the intake gasket, the throttle body gasket, and the cold start valve gasket. My dad suggested I get some special sealant that is used for aluminum engine parts. Any suggestions in that regard?
Raceboy
PostPosted: Sat Jun 25, 2005 4:45 am    Post subject: Reply with quote
Personally I don't use any gaskets on the intake side (TB, manif. to head, etc), only good black coloured, oil and temp resistant sealant. Holds much better and it's a lot easier to find I bet Porsche would have done sthe same if there would be such thing back in that time It's a matter of preferance but as things improve over time, so should our little monsters
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
augidog
PostPosted: Sat Jun 25, 2005 11:10 am    Post subject: Reply with quote
17 ft pounds --I just did mine
Paul wrote:
Some gasket material and a small ball pein hammer is all you need...
It would take me about 3 minutes to make that gasket.
I made all mine except intake manifold with Corecto gasket material.
I would have done the intake also but I allready had the gasket.
I was told to put the intake gasket in dry.
$5.00 and I still have bunches more of material.
Thanks Paul
