Paul924
Joined: 19 Apr 2003 Posts: 73 Location: Minneapolis, MN / Ames, IA
Posted: Sun Jun 19, 2005 5:59 am Post subject: outter tie rods.... (larger images...) |
ok, so i ordered one complete outter tie rod and one tie rod end (i didnt have the money to get two complete ends, but it is just the one that is bad, the other one is just fine..) and the ends are different, but is it simply a brand thing or should i call paragon products and bitch at them... or would it be safe to install... pictures below to help... i do like the codder pin safty aspect, as to just the nylon insert....
 _________________ 1979 924 NA |
Diesel
Posted: Sun Jun 19, 2005 6:02 am Post subject: |
Both are safe. I have installed both types on my cars and they are the same. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
Paul924
Posted: Sun Jun 19, 2005 7:40 am Post subject: |
one of each side? i would think you need a matching pair? _________________ 1979 924 NA |
Posted: Sun Jun 19, 2005 8:38 am Post subject: |
Threads are different also, the nylon one has a finer thread.
Both should be ok though _________________ Porsche 924 1984 (UK import) NA
numbbers
Posted: Sun Jun 19, 2005 9:16 am Post subject: |
They both will work, but I would never change just one. You want them to match. _________________ 1980 924 Turbo |
Llamaguy
Posted: Tue Jun 21, 2005 5:41 am Post subject: |
i would think that as long as you had it aligned properly it wouldn't really matter. Just make sure you take off the plastic cover before you try and put it in. oops  _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
