Has anyone had a control module failure? /symptoms?
augidog
PostPosted: Mon Jun 13, 2005 3:29 am    Post subject: Has anyone had a control module failure? /symptoms? Reply with quote
It can't last forever.
Jazzerpet
PostPosted: Tue Jun 14, 2005 10:26 am    Post subject: Reply with quote
I have not had one fail, But how is the car acting?
1985 ½ 944
Member of the “Omaha Crew”
augidog
PostPosted: Tue Jun 14, 2005 11:06 am    Post subject: Reply with quote
never a steady timing light since I had the car, always a very occasional slight miss.( Bad performance under under load with knock like sound. back fire on deceleration. But I may have a crack or leak at the exhaust manifold gasket
MunkPuppy
PostPosted: Tue Jun 14, 2005 3:23 pm    Post subject: Reply with quote
I've NEVER seen a stable timing light, so don't let that discourage you.
Check for clean grounding point, and also do the checks in the Hayes manual for the ignition module (It's in my car which is about 30Km away so I couldn't tell you what page it is on ) it's in the section that covers the ignition system
'80 931 FOR SALE
-Anton Szandor LaVey
augidog
PostPosted: Sun Jun 19, 2005 11:48 am    Post subject: Reply with quote
I went from a 1978 original unit to an 1980.
The car runs smoother all the way around.
I see them a lot on Ebay now going cheap.
I would not pay more than $20.00 but---
If you have an old original unit , I think you will benifit from buying a newer unit if possible.
I opened my old one up.
I'll post some pictures later so you can see what they are all about.
I think there is an upgrade after market unit for those more financially endowed.
It might be worth looking into.
One less worry.
