Injector holder source
joe
PostPosted: Fri Jun 17, 2005 11:19 am    Post subject: Injector holder source Reply with quote
Would anyone be able to tell me where I might find an injector holder for a 80 931?
Is it a porsche specific part or could I get one from something else?
thank you
Paul924
PostPosted: Fri Jun 17, 2005 11:46 am    Post subject: Reply with quote
are you speaking of the injector socket or the rubber o-ring.... i suggest you get the o-ring if it is the injector sockets anyways...
http://www.performanceproducts.com/productpage.aspx?pid=103510&name=Injector%20Insert&part=904154&type=20
http://www.performanceproducts.com/productpage.aspx?pid=102692&name=Fuel%20Injector%20O-Rings&part=904155&type=20
1979 924 NA
MunkPuppy
PostPosted: Fri Jun 17, 2005 1:01 pm    Post subject: Reply with quote
sadly, it is a porsche specific part. I don't remember the cost, but they aren't too much.
Paul, the Turbo (931) has screw-in injector bungs, to keep the injectors from popping out under boost. The non-Turbo models have only O-rings because obviously there is no boost, and the intake vacuum holds them in place.
'80 931 FOR SALE
-Anton Szandor LaVey
PostPosted: Fri Jun 17, 2005 6:31 pm    Post subject: Reply with quote
I am not sure, VW may have something you can use since they sold cars with the G40 and G60 G-Lader (supercharger). The injector inserts used on some normally aspired fuel injected VWs were teh same as those used on the 924, so maybe they used some of the same (or a compatible) inserts.
You could try taking out one of your surviving one/s inserts, and going to your local VW dealer to see if they have something that matches up.
numbbers
PostPosted: Sat Jun 18, 2005 9:55 am    Post subject: Reply with quote
Are you guys talking the plastic injector adapters?
